Vandiesel, I did not contact Sulastic after I removed them. Two years ago when mine went out I made the decision that this project exercise is complete for me and moved in another direction for my front suspension. I have been running the same 2" longer solid shackle seen above (this has centered the neutral ride height in the axle travel and added yet another inch up to the bump stops), added limit straps (after realizing a lot of my harshness was the shocks bottoming out even on modest bumps) and adjusting the tow angle to 0 degrees. This configuration is working well as the non - Sulastic configuration.
Internet reviews regarding the company seems to be that they will likely send out a replacement without protest. And, that could be an option to just replace them every couple of years as a wear item. Albeit an expensive one. I believe the design is great and produces the intended result, however the current elastomer, in this model at least, is not suited for our weight of vehicle or terrain we drive.
- Eric
2005 SMB RB 4x4 6.0 PSD
A rocket on the pad is safe,
