Old 12-03-2016, 10:50 AM   #51
Bolted on a few items this week!
Bolted on a few items this week:
1. Roof rack
2. Side ladder
3. Solar Panels
4. New pup
pmcypress is offline   Reply With Quote
Old 12-03-2016, 10:59 AM   #52
Flux's Avatar
Lookin real good!!
Old 12-04-2016, 06:52 AM   #53
Sweet! what did you select for panels and controller? how much house battery do you have?
Old 12-04-2016, 09:26 AM   #54
Solar setup:
Hi Boywonder,
I am using a Goal Zero Yeti 1250 to power the house. It uses a Group 31, 12V, 100Ah battery then I have it chained to a VMax MR127 12 volt 100Ah AGM deep cycle SLA maintenace free battery. The goal zero has a built in charge controller, so no need for one. I am using 2 Renogy 100 watt 12 volt monocrystalline solar panels.
Goal zero Yeti 1250:Goal Zero Yeti 1250 Solar Generator | Power Packs | Goal Zero
VMax Battery:https://www.amazon.com/VMAX-MR127-Ma...ilpage_o04_s00
Renogy Solar Panels:https://www.amazon.com/Renogy-Watts-...ar+panel&psc=1
Old 12-04-2016, 09:33 AM   #55
Solar setup:
Sorry forgot to show you how it looks in the van.
Old 07-05-2019, 12:56 PM   #56
OutlawImages's Avatar
Originally Posted by pmcypress View Post
I ordered the window tags from Amazon (They are custom military name tags.) I used small rubber blocks also purchased from Amazon to hold them in.
Can you post name or part#, searched amazon and hundreds of rubber blocks but dont see these
Thanks
2001 Ford E150 HighTop Conversion
Based out of the Sacramento Valley
Northern California
OutlawImages is offline   Reply With Quote
Old 07-06-2019, 10:23 AM   #57
Here is the information:
4 Small Rectangular Rubber Feet Bumpers - .344 H X 1.768 L X .885 W - Made in USA
by RUBBERFEET US
Learn more: https://www.amazon.com/dp/B00S4DV64Y..._MMmiDb8TBY3CJ
Paul
Old 07-06-2019, 06:05 PM   #58
Otter's Avatar
This is a great build. Nice quality and well thought-out.
I’m doing something very similar - sans couch/bed - with my 350 passenger. I have 2 questions I hope you’ll answer:
1 - It appears from your pics that you kept the original trim all around. Did you attach your cabinets to the van sides? If so, how? Any pics? Any insulation in there?
2 - Your Yeti system is simplified and interesting. Are you still happy with it? Does it still provide you with the power you need?
Thanks in advance!
Old 07-06-2019, 09:35 PM   #59
by RUBBERFEET US
Paul
Thanks so much I appreciate it
Northern California
Old 07-07-2019, 01:24 PM   #60
I did pull some of the trim behind the cabinets so I could get the cabinets a little closer to the driver’s side wall and I also did a cutout where the gas fill was. I insulated it with Dynamat and Dynapad and we also use some pink insulation from Home Depot. I bought bolts from McMaster Carr and went right through the bottom of the cabinets through the floor right into the frame using the original seat mount holes. As far as the gold zero I loved it. It was basically plug-and-play it had a built-in inverter, solar controller everything was in it and I chained it to another battery as you can see in the pictures. I live in Southern California and never had a problem with power most of my camping was done in the west. I did sell the van about a year ago and I now have a new rig a Four Wheel Camper on a Ford F350 diesel truck.
980AD40D-5727-4AA5-94DA-282D1947427C.gif   5F76A429-EECF-478D-AE63-D35A651AA83F.jpg   DA2088A6-3C50-4DED-A772-359E5036FDCA.jpg
