Old 11-06-2018, 04:59 PM   #21
bfolens's Avatar
Originally Posted by Bbasso View Post
I think I know the owner/van. If so, it's nice.
Really. Would be fun;-) the van is now in California. I need to run a car fax to get the details of the number of owner.
bfolens is offline   Reply With Quote
Old 11-06-2018, 05:20 PM   #22
marret's Avatar
I was going to suggest a carfax. It looks like the van lived at least part of its life somewhere other than CA.
Does the canvas/fabric on the roof need replacement? You made a comment. You might check to see about replacing it if so before making an offer. I don't know if the current GTRV company will replace existing canvas.
Chris
Old 11-06-2018, 05:24 PM   #23
Seems like a lot. Down here a similar van sold for $17k with absolutely no rust. They are tough to find, but not so tough that you should buy a rusty one. I would offer $13-14k and stick to it. For the few thousand difference you could pay to have the rust taken care of.
Old 11-06-2018, 05:33 PM   #24
bfolens's Avatar
Thanks, guys.
I have ordered a pre-inspection for next Tuesday and looking for carfax now. Not place before.
The fabric on the canvas is ok but looks like there is so black spot (humidity?) it did not smell that much but the guy said that he will get it to replace if I am taking it at 15k. So, I am sure there is room for negotiation.
I am not a big fan of rust, to be honest, but I am fine to get it cleaned if the maths work. The tires look good but the ball joints need to be replaced. Let me had more pictures here.
The good one is that it "technically" fit into the garage:-)
IMG_4475.jpg   IMG_20181105_110514.jpg   IMG_20181105_110533.jpg   IMG_20181105_110549.jpg   IMG_20181105_110736.jpg
Ford Econoline 150 - 2001 - 4.6l - GTRV
Old 11-06-2018, 05:35 PM   #25
bfolens's Avatar
Originally Posted by marret View Post
Good luck. Look in the driver door jamb for GVWR and GAWR. Have to ask for weight or take it to a scale. Might be a GTRV sticker with weights in the door jamb.
I think those are the information you mentioned correct?
Old 11-06-2018, 05:43 PM   #26
There is something to be said for a vehicle that is close by and will fit in the garage. If he will negotiate, I say go for it!
Old 11-06-2018, 05:53 PM   #27
marret's Avatar
Yes, that is the Ford weight decal. There should be a GTRV decal as well with possibly the CCC, cargo carrying capacity.
The GVWR is 7000 pounds. I'd want to know what the weight is now with the conversion. The GVWR minus the weight is what you have left for people, fuel, water, supplies, etc. 7000 isn't too bad, but weight adds up quickly.
The van needs some work, so I'm with Grampswrx on offers and negotiation. Finding one that will fit in the garage at 6'9" will be a challenge. Factor in what it will take to fix. You might want to get a quote to take care of the under carriage.
Chris
Old 11-06-2018, 09:24 PM   #28
mikracer's Avatar
Based on the H9 axle code, it's a 3.55 with limited slip. Might be ok with the small motor and interior build out, but my guess it is will be right lane only when going up grades.
Like others have said, negotiate hard and use the rust as leverage.
Old 11-06-2018, 10:55 PM   #29
bfolens's Avatar
Thanks for confirming this. I test drive and it drive smooth and shift smoothly. But it is not a Ferrari;-)
Old 11-07-2018, 12:27 PM   #30
bfolens's Avatar
Hi All,
I am drafting a quick note for a mechanic guy that will do the pre-inspection for me. I cannot be there when he is doing it, so I need to list all of the attention points. I have drafted below my first thoughts. Can you please let me know if I have missed something important?
- The general state of the engine
- Head gasket (no Leaking)
- Serpentine
- Water pump
- Transmission (no noise, no clunk)
- Rust on the body? Surface, need change?
- Computer check (reading code)
- Test drive
- Oil Leaking
- Check Ignition Coil
- Test AC
- Brake pads and rotor
