I think I will get this stove/oven from Costco, great review
Expand your outdoor menu with Camp Chefs Outdoor Camp Oven. The twin burner range allows you to fry and boil while your favorite dish bakes to perfection in the dual-rack oven. Featuring two 7,500 BTU brass burners and a 3,000 BTU oven burner, the versatile Outdoor Camp Oven unlocks all the cooking capabilities of a home oven and range. The unit's heat-efficient, insulated oven box heats up to 400 F and has plenty of room to fit a 9 x 13 pan in it. A see-through glass window and built-in temperature gauge help you hone your cooking skills. The first of its kind, the Outdoor Camp Oven is easy to bake with and fun to use anywhere your travels take you. Durable powder-coated steel construction helps fend off corrosion and nonstick enamel makes cleanup easy as pie.
Perfect for baking fresh bread and cookies, pizza, lasagna and so much more. The Outdoor Camp Oven enables you with endless cooking possibilities whether at camp, down by the lake, tailgating, or at your own backyard barbecue. The package includes a 20-Inch Non-Stick griddle for frying your favorite breakfasts; hamburgers, hot dogs, steaks.
Features:
Matchless Igniter burners
Powder-Coat Steel construction
Nonstick enamel cooking surface
Built-in Oven thermometer
2 oven racks.
20 Non-stick Griddle
Powered by a disposable 1lb propane tank - Can be adapted to use a 20lb tank
Specifications:
Range: 7,500 BTU's per burner
Oven: 3,000 BTU's
Top burner dimensions: 12" x 21"
Inside Oven dimensions: 16" W x 8.5" H x 10" L
Top oven heat: 400 degrees
Weight: 40 lbs.
Thanks, Tiger
