Old 12-21-2012, 07:36 PM   #1
92 Ford Preventative Maintenance
Hey guys, Mike from Birmingham here. I have a 92 E350 5.8 Club Wagon I use to haul my dirt bikes to riding spots and events and also do some camping. I've owned the van for 13 years and always thought it was the perfect vehicle for that. I have a few trips planned next spring and need to do some preventative maintenance. I've tried to take good care of it but the fact that its 20 years old means that anything can go wrong anytime. I have the basic maintenance covered, I'm looking for the things that are likely to go bad with these older fords and leave me stranded on the side of the road. Mileage is 187k. I replaced the engine with a Jasper reman. and it has 37K on it now. Here's a short list of things I replaced since the engine was replaced. Computer, alternator, radiator, and most recently distributer stator, ICM, coil, dist. cap, rotor, throttle position sensor, fuel filter and this week, heater hoses. I had some issues with the engine dying but restarting after cooling off. This stranded me twice, had it in the shop twice but they could not reproduce the problem. After some research I decided the most likely culprit was the distributer and ICM. I replaced them with Motorcraft parts and it has not died again (but I haven't been on any long trips either). Anyway, maybe you guys can give me some ideas, I hate breaking down.
MWL52 is offline   Reply With Quote
Old 12-21-2012, 08:34 PM   #2
Re: 92 Ford Preventative Maintenance
Did it die suddenly? Or lose power first. If it lost power first before it stalled, its most likely the fuel pump. If it's never been replaced, you are on borrowed time (the updated Ford version lasts longer, so it would probably be the last you put it.).
Otherwise, you seem to have the engine's problem areas covered. Was the T-stat replaced when the radiator was done?
Do you know if the transmission has ever been done? The E4OD was about 200,000 mile transmission behind a gasser (and about half that behind a diesel).
Old 12-21-2012, 09:47 PM   #3
It died suddenly. After about 30 minutes it would restart and run 1/4 mile or so and die again. After sitting all night at a repair shop it cranked and ran fine. I'll put the fuel pump on the list to be replaced. The thermostat was replaced with the new motor. The trans works great. The previous owner said he had rebuilt the trans but I don't really know for sure.
thanks
Old 12-21-2012, 09:54 PM   #4
Sounds like a crack in the PCM that was heat affected- usually the only thing you can do is replace the computer and wait to see if it went away.
Old 12-21-2012, 10:30 PM   #5
The rebuilt computer has about 25k miles of use. Haven't heard of a cracked PCM. Is that a common problem ?
Old 12-21-2012, 11:03 PM   #6
rockbender's Avatar
I hate to suggest just being a parts replacer, but if a coil isn't too expensive I'd try replacing that again. Check the distributor cap for cracks too.
Josh
Old 12-21-2012, 11:37 PM   #7
Crobins937's Avatar
Do you remember what the cost was to do the jasper rebuilt motor and install?
Crobins937 is offline   Reply With Quote
Old 12-22-2012, 07:16 AM   #8
I replaced the coil, cap and rotor when I did the dist. stator and ICM. It runs good now but the longest I've driven it is 2 hours at a time. Not 100% sure I fixed the problem.
Old 12-22-2012, 07:20 AM   #9
Motor and install kit was $2000 and about $900 labor. It's been a while since I had that work done, so the price has probably gone up.
Old 12-22-2012, 12:54 PM   #10
My recent Jasper 5.4 was about 4500 total. That's turn key though, I dropped it off and did none of the work.
MoMo
skyrat
VivaLaVida
Pschitt
