Originally Posted by bhamBaker
Twoxentrix;
Why did you go w the second unit over the first?
Been searching for a upgraded cooler for my '06 5.4gasser transcooler.
I have the 6.0 diesel and have been focusing on managing my temps and the Trans cooler was the last of those projects; since the Van weights 11,800lbs it works harder in many situations.
The Mishimoto trans cooler is 3x the size of the OEM trans cooler I had, and quite frankly I really didn’t want to put something larger in front of my radiator.
I was attracted to the Derale Hypercool because it has a fan, allowing me to manually engage it when I needed it most. This helps tremendously when going slow since you get very little air going through the front grill. The Derale is mounted just behind the transmission and above the rear driveshaft. It’s set up so the trans fluid goes through it first, then continues it’s normal path to the radiator & OEM trans cooler.
The result has been better than expected. It’s set up with a thermostat and a dash over-ride. Have had to adjust the thermostat numerous times just to get trans temp up to the 170 degree mark. I’ve had it installed about 3 months now and haven’t seen the temp go higher than 180 on a long steep grade … also had the van on sections of the Blue Ridge Parkway that are slow and steep with same result. Oddly enough the unexpected benefit has been the coolant and oil temps are now about 5 degrees lower as well since it seems we’ve managed to eliminate heat prior to the fluid reaching the radiator.
I would imagine similar results would/could be realized in a gasser.
