Old 02-26-2021, 09:09 AM   #1
DIY Van Head Studs
I didn't have any luck searching, but has anyone posted a good DIY head stud replacement procedure on the 6.0 for the vans? Easy to find them for the trucks, not so much for the SMB/vans
Thanks.
leblanc is offline   Reply With Quote
Old 02-26-2021, 09:20 AM   #2
Jeffrey's Avatar
What engine?
Old 02-26-2021, 09:43 AM   #3
Originally Posted by Jeffrey View Post
What engine?
Sorry... edited with “6.0”.
Old 02-26-2021, 12:34 PM   #4
There was a thread about this a couple months back. I know it can be done on the F series without a cab off or pulling the engine but access to the heads is much more difficult on the vans with a 6.0.
edit to add the previous thread: https://www.sportsmobileforum.com/fo...off-21438.html
2011 VW TDI Golf for hwy fun
Old 02-27-2021, 05:03 AM   #5
New gaskets?
hogasm is offline   Reply With Quote
Old 02-27-2021, 07:07 AM   #6
Well, yeah... the whole process. Remove heads, inspect, install new gaskets, install the studs, torque, finish. It just seems like the video or photo documented process for the vans is very elusive.
Old 02-27-2021, 08:18 AM   #7
My bad I thought you were referring to stud installation without pulling the heads or the motor.
It's really no different from the trucks except for the engine needing to come out the front.
Old 02-27-2021, 08:35 AM   #8
Just looking for any documented process with the van. Preferably would love to see if anyone has done it without pulling the motor or lifting the body completely off.
Old 02-27-2021, 08:49 AM   #9
For what it's worth, stock 6.0's in vans don't typically have head gasket issues since they are de tuned by 80hp. The exception would be EGR failure leading to coolant into the system.
Desert Solitaire
2003 7.3L EB 4x4
Timberline 4x4 conversion
Old 02-27-2021, 08:58 AM   #10
I don't think it can be done. Just doing injectors on the passenger side requires raising the motor, removing the engine mount, and then lowering the motor. And that's if you have small hands.
