Originally Posted by carringb
SCT tune is likely to cause high EGTs on the E-series, because of the smaller inter cooler and lower volume intake. Definitely keep an eye on things when towing.
Finally got my EGT installed a couple weeks ago and have been monitoring during normal driving and a short HWY towing trip (hauling midsize suv on a tandem car hauler) probably under 8000lb.
I have been using the SCT stock +65 hp tune for the past 4-5 years without EGT monitoring. After the warning above and my oil cooler failing I was a little concerned about my lack of research on this subject rather heading the advice of a mechanic friend which was based on F series.
Thankfully EGTs seem to agree with what have been posted here and elsewhere. EGTs at idle are 300F, cruise 600-700, dipping into power 700-800F. I was very cautious while towing, EGTs were 700-900 never cracked 1000F using when tow bottom on trans. I could easily see how temps could come up if using overdrive.
These are taken from the passenger side manifold, hopefully neither side runs leaner than the other. I chose to install the EGT on the top of the passenger side manifold this seemed to be the best compromise of location routing and installation access for me. To anyone doing this do not get greedy with the tap, I almost over tapped the NPT threads, which would allow the fitting to bottom without tightening.
Also back on topic for this thread after changing the oil cooler and HPOP fitting, I can’t see anyway that studs could be don in the van without significantly lowering the engine.
