Old 03-09-2024, 09:07 AM   #1
Pimpon's Avatar
Pimpon Dana 60
Hello, I have a problem with reassembly,
when I mount the whole shaft no longer turns we will say that it is not the good jonts sos
Dana 60.PNG   20240308_155226[1].jpg   20240308_154938[1].jpg   20240308_154950[1].jpg
-1995 E350-7.3 Quigley -1993 Toyota HJD 80 -1990 Toyota HZJ 70 -1980 Toyota BJ 42
https://www.facebook.com/profile.php?id=100064197488075
Pimpon is offline   Reply With Quote
Old 03-09-2024, 10:09 AM   #2
Are you saying that the axle does not rotate once installed in the differential?
Does it turn when you rotate the input yoke?
kbeefy is offline   Reply With Quote
Old 03-10-2024, 01:56 AM   #3
Pimpon's Avatar
when I aim at the rocket it compresses the 2 joints and I can no longer turn the shaft
Old 03-10-2024, 05:13 PM   #4
I think we are losing something in the translation here.....
Does the long shaft spline slip into the differential fully? When both axles are straight (in line with each other) does the axle turn?
If you turn the input yoke on the differential does the axle turn?
Are you saying that the U-joint binds when bending the axle sharply?
...or when you install the spindle over the outer stub shaft it binds?
Old 03-10-2024, 07:00 PM   #5
I was hoping a French translator might stop in.
Old 03-11-2024, 06:44 AM   #6
Pimpon: A universal joint (U-joint..it's technically a cardan joint) is rather primitive compared to a say a CV (constant velocity) joint. Based on the pictures above, if you are trying to turn the short stub shaft with your hand at large angles it's going to be very difficult/impossible because of the basic properties of a U-joint.
When you flex a U-joint the output shaft rotation (compared to the input shaft) is not constant. The output shaft will rotate with a sinusoidal component....this will make it easier/harder to rotate depending on the position of the U-joint as it rotates when rotating at a large angle.
At large angles it gets quite hard to turn ......you can simulate this with a flex universal socket and a ratchet.
This is why most modern vehicles use CV joints, they run smoother and are more efficient.
Here are a couple graphs of the input to output shaft relationship
Old 03-11-2024, 10:32 AM   #7
Pimpon's Avatar
it's not coming from the U joint
Old 03-11-2024, 10:39 AM   #8
Pimpon's Avatar
for me I'm not sure of the correct gasket reference
when there are no joints everything is fine the shaft turns well
Old 03-11-2024, 10:52 AM   #9
Oh. Dust shields.
They're not really necessary. I believe the inner one should be pressed into the axle housing instead of hanging on the axle shaft.
Old 03-11-2024, 10:55 AM   #10
Pimpon's Avatar
Originally Posted by kbeefy View Post
Oh. Dust shields.
it does not fit into the normal housing or not
"Campy"
campy
Jnlola
jnlola
