Old 03-11-2024, 11:05 AM   #11
Pimpon's Avatar
Does it not fit into the normal crankcase or did I order the correct gasket?
https://torqueking.com/xv1011-1995-1...exploded-view/
-1995 E350-7.3 Quigley -1993 Toyota HJD 80 -1990 Toyota HZJ 70 -1980 Toyota BJ 42
https://www.facebook.com/profile.php?id=100064197488075
Pimpon is offline   Reply With Quote
Old 03-11-2024, 11:06 AM   #12
Pimpon's Avatar
Old 03-11-2024, 11:35 AM   #13
That seal probably goes on the other end of the axle tube.....inside the differential housing....that's where the sealing happens on a Dana 60.
Old 03-11-2024, 12:49 PM   #14
Pimpon's Avatar
for me it's a dust seal No. 90
the gasket which makes it waterproof and securely in place No. 32
Old 03-11-2024, 01:11 PM   #15
Some people argue that those seals trap water in the axle tube and promote rust. I've ran many vehicles without them and never had an issue.
kbeefy is offline   Reply With Quote
Old 03-11-2024, 02:18 PM   #16
Can you post a picture of seal #32?
The seal that you are holding in your hand in the picture above looks like seal #32.
Old 03-11-2024, 11:18 PM   #17
Pimpon's Avatar
I put this one as seal 32 from RockAuto
Old 03-11-2024, 11:20 PM   #18
Pimpon's Avatar
You may be right about the fact that the humidity remains trapped.
Old 03-12-2024, 07:14 AM   #19
Yes that is correct for seal #32
Old 03-12-2024, 12:56 PM   #20
Pimpon's Avatar
I'm going to go back and not put the 90 joint to see
Biggie
Berta
TBD
thatsandrea
