Old 03-09-2024, 09:25 AM   #1
Pimpon's Avatar
Pimpon Drive shaft
still a problem with reassembly I manage to get the right seal what is the right Reference the diameter is too big :confus:
-1995 E350-7.3 Quigley -1993 Toyota HJD 80 -1990 Toyota HZJ 70 -1980 Toyota BJ 42
https://www.facebook.com/profile.php?id=100064197488075
Pimpon is offline   Reply With Quote
Old 03-11-2024, 10:53 AM   #2
Pimpon's Avatar
still not found the correct U joint reference
Old 03-28-2024, 10:50 PM   #3
Pimpon's Avatar
Hello everyone still waiting for your help I can't find the reference for ujoint AV
Old 03-28-2024, 11:46 PM   #4
Twoxentrix's Avatar
Vincent, I'm not an expert on drivetrain components on these Vans, but I believe you should first contact Quigley since they did the 4x4 conversion. It's my understanding if you provide them with the Van's VIN Number they can tell you exactly what you need (I have no idea if the 2WD and 4WD units used the same drive shaft & u-joints, but it would seem logical they would have moved to a larger one after installing a transfer case & shortening the drive shaft)
QUIGLEY MOTOR
COMPANY, INC.
100 Sunset Drive
Manchester, PA 17345
(800) 233-9358
https://www.quigley4x4.com/contact-us/
Here is a link utilizing 'size' charts:
https://www.google.com/search?q=ford...a46TyM&vssid=l
I received your e-mail and will wait 2 more days before I ship the tail lights. This way if you locate the correct u-joints you can let me know and i will hold off sending the lights until I receive the u-joints since I can probably get a better deal on shipping them together...just let me know if you find what you need through Quigley or utilizing the 'size' charts.
Old 03-29-2024, 08:16 AM   #5
Vincent:
What are the dimensions that you need for D1/D2 and G1/G2?
..assuming D1=D2 and G1=G2
EDIT: I see that D1/D2=26.97mm......still need G1/G2
Check out this video:
https://spicerparts.com/videos/how-t...iversal-joints
Old 04-10-2024, 10:21 PM   #6
Pimpon's Avatar
Vincent:
Here are the measurements again thank you
Old 04-11-2024, 08:37 AM   #7
Vincent...this has proved to be a bit of a challenge.......
Your image above shows both the yoke width and end to end bearing cap distance to be 95mm.....
Can you re-measure the width of the U-Joint end-to-end across the bearing caps?
If they are 92mm end-to-end there are lots of U-joints that size......
A 95mm yoke width with 1.5mm retaining rings would need a 92mm wide U-joint.
Thanks
Old 04-11-2024, 09:02 PM   #8
KTMRIDER's Avatar
They do make a UNOINT that converts two different sized yokes. Are you saying two sides match up and two sides are wider/smaller? I can get the part number for the one I am aware of if this is the case.
KTMRIDER is offline   Reply With Quote
Old 04-11-2024, 09:59 PM   #9
I stumbled across Strange Engineering and indeed they offer various conversion U-joints; however I couldn't find one suitable for this application.
If the OP's u-joint is 92mm across the bearings end to end, then there are plenty of candidates. If it's truly 95mm/3.75" width and 27mm/1.062" bearing cap diameter I'm coming up empty handed...which doesn't make sense...at least to me.
Old 04-13-2024, 10:44 AM   #10
Pimpon's Avatar
Thanks
yes indeed 92 mm
Vanna
gahamby
AWOL
Twoxentrix
