Old 07-15-2009, 09:10 AM   #1
Mahukaawe's Avatar
Quick air bag question
If you go with the manual fill instead of the remote (on the dash) fill with the rear air bags, how do you do it?
Do you go with the hose and fill each bag to raise psi? and how do you lower psi. Is it like a regular valve stem on a tire?
The remote fill seems pretty expensive.
Thanks
Harry
09 E350 EB 6.0PSD SMB 4x4 kind of a 61 layout
02 F450 Flatbed 4x4 7.3 PSD
08 F150 5.4 ltr 4x4 Daily Driver
77 Orig Bronco in rebuild mode "uncut"
76 Orig Bronco rebuilt & driven weekly
71 Orig Bronco rebuilt & 4sale gots everything on it
Owned a jimmy once for about 6 months.
https://www.tropicalgardensofmaui.com
https://www.mauicabins.com
twitter @runnin6mpg
Mahukaawe is offline   Reply With Quote
Old 07-15-2009, 12:30 PM   #2
Re: Quick air bag question
Harry, Most have a pig tail type air lead that you just reach in and fill just like a tire. I've seen some with bleeds and some plum the lines to an easy access point. There are pros and cons to all the setups. Mine are controlled from the cab. I can adjust to the trail as needed including leveling on off camber situations. But I seem to always have a slight leak and have to pump them up weekly. No big deal with an extreme air compressor on board.
Dave
Old 07-15-2009, 04:17 PM   #3
I recommend not installing a tee to fill both bags together. This will allow for air transfer, which will increase bodyroll (sometimes significantly)
Old 07-15-2009, 05:37 PM   #4
surfgeek33's Avatar
Found this on Ebay, thought you might be interested.
http://cgi.ebay.com/ebaymotors/ws/eB...ht_3494wt_1131
"I do, cellularSTEVE" :o)
Old 07-16-2009, 10:23 AM   #5
yes that's correct, I was thinking air shocks on that one. I edited out that part of my post as it could be a safety factor. Thanks.
Van22
Van22
Big Grey
allenl
