Transmission Pan Bolt Torque Spec
Greetings, just discovered leakage around the transmission pan on our 2013 Super Duty V-10 E350 and want to check bolt tightness before digging deeper. Quick question: What are the transmission pan bolt torque specs for the 20 fasteners holding the pan? Owner’s manual and Haynes don’t list values, search on this forum came up empty, while a thread on Ford truck forum lists 10-12 foot lbs. for F-series. Just want to confirm if that is the correct range for the van. Thanks!
