Originally Posted by Earle
Rizzabove
What fitting did you use on the tank to plumb the diesel pick up tube in?
Did that silver fitting come with your heater?
Clean looking install!
I got a recent Chineeze petrol/gas heater with a similar-looking tank pickup. I think you need to remove the fuel pump/sensor assembly to insert the pickup from the inside out and screw the washer and rubber gasket down under the nut.
In a Stock pre-2008 sensor/pump assembly there looks like enough room so that you can drill the pickup hole in the stock assembly is there is so spare hole in your tank.
