Old 12-08-2023, 07:27 PM   #11
Heres a link to a dimmer that is the same maker as the lights I have installed. I didn't realize they made these smaller dimmers.
https://www.amazon.com/Dimmer-Dimmin...itle_auto?th=1
stevigee is online now   Reply With Quote
Old 12-08-2023, 07:36 PM   #12
That's a PWM (pulse width modulation) dimmer.....a bit more modern (and efficient) than a simple pot. I would still confirm it does what you want before cutting/drilling any metal, but that should work fine.
Old 12-08-2023, 07:36 PM   #13
I think this is the first switch I posted.
https://www.amazon.com/ALOVECO-Inter...lbWF0aWM&psc=1
Old 12-09-2023, 08:33 AM   #14
Yes .....same one ...PWM..should work fine. Again I'd try it with the lights on the bench before cutting/drilling anything but it should work fine.
Old 12-09-2023, 09:27 AM   #15
You need PWM style dimmers for LEDs or they become very touchy. A little change in voltage goes a long way with LED brightness and diodes are not always consistent so if you have multiple lights on the same circuit they will be at different brightness.
Easy button may be a remote control like this?
https://evandesigns.com/products/rem...b&gad_source=1
Colorado Camper Van uses a combo of this controller
https://www.superbrightleds.com/cata...8a/category/2/
and this remote
https://www.superbrightleds.com/wire...ller-ezd-1c-wm
and this remote
https://www.superbrightleds.com/mini...ller-ezd-1c-pb
Big_ern_101 is offline   Reply With Quote
Old 12-10-2023, 10:39 AM   #16
gahamby's Avatar
You could "fish" one of those small pots up into the pillar through a small hole. I've installed trailer hitches in two cars that came with spring steel wires for pulling bolts into frame members. Leave long leads on the dimmer so you can do the connections down low.
'07 GMC 2500 6.0
Old 12-10-2023, 11:24 AM   #17
gahamby's Avatar
https://www.sportsmobileforum.com/fo...ture48535.jpeg
Like these.
'07 GMC 2500 6.0
Old 12-11-2023, 08:38 AM   #18
The dimmers in the link I offered are wireless/battery powered. You can put the controller anywhere and then the dimmer anywhere, could likely just drill a hole in the plastic trim and tuck it in an existing body cavity. I also wouldnt feel too bad about taking a step drill to the B pillar and drilling a 1" hole. Thats a lot less intrusive than cutting a big square for a junction box with sharp corners.
Old 12-11-2023, 12:11 PM   #19
gahamby's Avatar
https://www.recpro.com/rv-12v-dc-tog...immer-control/
'07 GMC 2500 6.0
Old 12-12-2023, 10:54 AM   #20
Orv
I use this one with my LED strips:
https://www.superlightingled.com/dm1...er-p-3136.html
It's surface mount so might not work if you're going for a super clean look, but it's PWM and runs quite cool, and you don't have to cut any holes. It doesn't technically have an "off" switch but at the fully dimmed position the LEDs are no longer lit and the power drain is low enough that it hasn't been a problem for me. If you routinely park the van for months at a time you might want a separate off switch (although in that case you're probably going to be using a battery disconnect anyway.)
N8SRE
Ann the Van
Bongo
Esme
Amy V
