Looks like the bolt broke? As Joe said, the bolts that hold the latches extend all the way through the roof - I assume that the nut/washer and remaining section of the bolt are probably still in place (and stuck with butyl) on the top of the penthouse. You should be able to either just unscrew the nut on the exterior of the pop top or pry it up via the washer. Just use a screwdriver to pop the black plastic cover off first. Be sure to use an appropriate amount of butyl putty when you reassemble so that you don't get any water leaks.
2001 Sportsmobile RB50 7.3
West Central Mountains, Idaho
