Re: Espar Heater Question
Keith,
This is from my Installation instructions for the "High Altitude Compensating Device" Espar Kit #20.2900.70.007 ... "The Espar High Altitude Device is used in conjunction with all Espar heaters using a Dosing pump in 12 or 24 volts. This includes Artronic 2/4/5 (gasoline or diesel version) ... models". The compensating device shouldn't be a factor in choosing which model heater to install.
Also, FYI, the heater installation manual recommends that you "keep 2" clear to any flammable or heat sensitive material."
hope that helps.
/~fred
