If you can disconnect your solar from your batteries so you are just running off of your house batteries you could then check your battery voltage. The fridge has a low voltage cut-off that will turn the fridge off if the battery's voltage is below 10.9 volts. It also won't turn back on until the voltage coming from the battery is at least 12.2 volts. I would check that first if the fridge actually gets cold when operating on 110 AC shore power.
