Nor32 I didn't. but here's what I learned
The coating hides a little but not as much as you might hope.
Prep now or pay later, scuff everything with 80 grit.
I primed everything with epoxy primer, if you have the compressor, it's not much more work to get a virgin surface.
Spray both vertical and horizontal coats or when the light is right you will see the lines.
Mask everything within 15' of what your spraying.
Don't put on too thick of a coat, do several coats, like 3 or 4
Be sure to have lacquer thinner around before you start.
2002 e350 window eb,
7.3
CCV high top
Conversion in process. Lol
Denver, CO
