Old 06-21-2023, 05:39 PM   #11
Nope, or ask in here for others to learn from
2002 e350 window eb,
7.3
CCV high top
Conversion in process. Lol
Denver, CO
Old 06-22-2023, 07:19 AM   #12
OK, thanks for your time and input.
blair is offline   Reply With Quote
Old 06-22-2023, 03:14 PM   #13
Did you happen to do a write up in the Raptor liner project?
You can follow my build
Instagram @TheDirtVan
YouTube- TheDirtVan
https://www.youtube.com/channel/UCSePTshSLn79BOCGYwSwPbQ?view_as=subscriber
NoR32 is offline   Reply With Quote
Old 06-22-2023, 06:32 PM   #14
Here's a good breakdown on youtube for prepping Rhino liner, I'm guessing they'd be similar if not the same.
MordikaiX is offline   Reply With Quote
Old 06-22-2023, 11:01 PM   #15
Nor32 I didn't. but here's what I learned
The coating hides a little but not as much as you might hope.
Prep now or pay later, scuff everything with 80 grit.
I primed everything with epoxy primer, if you have the compressor, it's not much more work to get a virgin surface.
Spray both vertical and horizontal coats or when the light is right you will see the lines.
Mask everything within 15' of what your spraying.
Don't put on too thick of a coat, do several coats, like 3 or 4
Be sure to have lacquer thinner around before you start.
7.3
CCV high top
Denver, CO
Old 06-22-2023, 11:15 PM   #16
Lilnuts2
That works for me. Do it once do it right.
YouTube- TheDirtVan
Old 06-23-2023, 11:54 AM   #17
NoR32, one last thing. If you get spray on anything you don't want it on, wipe it off immediately!!
7.3
CCV high top
Denver, CO
Old 06-24-2023, 11:59 PM   #18
SlimKiteGuy's Avatar
Originally Posted by blair View Post
I too am going to Rhino or Raptor liner some day. What made you decide on Rhino?
Would mind saying how much this costs?
Can you also share before and after pics?
I chose Raptor because of the DIY aspect of it. It cost me about $1300 all up but that included renting a paint booth for a whole day in Los Angeles. You can see my write-up on it in my van build post: https://www.sportsmobileforum.com/fo...awd-26987.html
2009 Chevy Express 1500 AWD SMB
SlimKiteGuy is offline   Reply With Quote
Old 06-25-2023, 07:18 AM   #19
great information. thanks. looks like a heck of a lot of work to do it right. I Plasti Dipped my ugly factory wheels, with minimal prep and effort. it has been a couple of years, and they still look fair. It looks like if I am gonna do a DIY Raptor a lot more work is gonna be needed.
Old 07-13-2023, 10:14 AM   #20
Probably a dumb question, but… Does the Raptor liner work on the Poptop only? I have a 2014 SMB and the top is starting to show weathering. Mainly hair line cracks. I was thinking a liner product would fill these and add protection. Any thoughts?
Surf Moia is offline   Reply With Quote
Vandit
aarcaris
Ford
fabtechmfg
