Old 03-22-2009, 12:55 AM   #1
XL Storage Compartment
Hi guys,
Just wondering if anyone here has interior dimensions for the XL Storage Compartment they install underneath the RB van? I can't seem to get this info from SMB. Thanks!
David
Trek777
Designing my first SMB.
Trek777 is offline   Reply With Quote
Old 03-22-2009, 01:53 PM   #2
Re: XL Storage Compartment
Trek 777
Just went out and measured mine.
32in. Wide, 21in. Fore & Aft, 16in. Deep, plus there is a shelf on the top front end that is 5in. High, and 4 1/2in. wide from front to back. In other words the top of the compartment in front gets longer (front to back) after it gets above the diff.
Hope this helps.
Bill
NO2B
Old 03-22-2009, 10:34 PM   #3
Thanks Bill! So does this compartment have flat sides inside like a regular box, or is it curved?
This is a big help.
David
Trek777
Old 03-22-2009, 10:37 PM   #4
geoffff's Avatar
Not curved. Mostly flat, but there's a "step" on the front wall, as you can see here:
-- Geoff
2004 Ford, SMB 4x4, RB-50
Old 03-22-2009, 11:04 PM   #5
So do you guys usually put a floor jack here or somewhere else?
David
Trek777
Old 03-22-2009, 11:09 PM   #6
Mine doesn't have the forward step in the front wall, an RB thing maybe?
The back, lets say 1/3 of the floor slopes up, but otherwise mine is a regular box. There is also a drain spigot in the center bottom of the floor, which is a drag because it's right in the way and sticks up.
Gives me a thread idea for tomorrow...
Old 03-22-2009, 11:14 PM   #7
geoffff's Avatar
David
My stock jack is in there under all that stuff, along with a Tirfor/Griphoist hand winch & cable, and various pipes and saws.
-- Geoff
Old 03-23-2009, 06:13 AM   #8
One more question for you. How large is the opening to the compartment? It looks somewhat smaller than the box itself, which I'm hoping is not smaller than 20 in. across.
Thanks a bunch!
David
Trek777
Old 03-23-2009, 09:03 AM   #9
Trek777
Jage is correct as to the slope of the floor. I checked mine out again and from approximately half the floor dimension fore and aft to the rear wall, it slopes up about 4 in. (To about 12 in. deep at the rear. The inner dimensions of the access hole, including the lip are: 17 3/4 fore and aft, and 20 3/4 side to side. The trap door is about 2 in. bigger both ways as it sits on the lip.
Bill
NO2B
Old 03-23-2009, 02:50 PM   #10
Interesting yours has a lock, mine doesn't. It slopes as well with no step and we have a EB.
Dave and Yoshi [Ki6LBB]
https://www.adventureduo.com
Tread Lightly! Trainer
Pack it in Pack it Out>>>> https://www.trasharoo.com
The Yeti
TexGX
The Toaster
CaptainG
