02-20-2019, 10:20 PM
#91
MG answered my question this past weekend. So I wanted to share it with other folks converting a 5.4 with 4r70. The stock 6.8L and 6.0L cross members are already 4" longer to clear the front drive shaft. Since the 4R70 is shorter though, you have to add a 4" block to space it back to the right location. I'll be on the lookout for a stocker from a 6.0L or 6.8L.
Originally Posted by Mikerson
I was talking about the transmission cross-member.
02-21-2019, 09:43 AM
#92
Just a little clarification cuz when I read this ^^^, I don't see the whole picture
When you are installing our radius arm brackets on a van with a 5.4L/4R75 trans, the radius arm bracket bolts to the frame where the trans cross member goes (the trans cross member sits farther forward on the frame than the other configs). The 4R75 cross member also sits up higher than the 4R100 and 5R110W. What needs to happen is that cross member has to move back behind the radius arm brackets (new holes drilled in frame) and the mount will have to drop down. On Jsweezy's van, he used a cross member from a V10 van (to get the drop down) and then fabricated an extension to bring the trans mount holes forward (the cross member is shifted back now but the trans mount holes have to come forward a bit to line up with the new tailhousing). He also made a relief in the cross member to give the front driveshaft more clearance.
There are few guys out there who've done this and if you have any pics, it would be helpful to post here.
02-21-2019, 11:03 AM
#93
Originally Posted by mgmetalworks
I will at some point do a write up of the ESOF install with pictures and part numbers list but for the time being, here's a quick run down.
(This is in reference to using controls from a ~2008-2009 NV273...probably the simplest set up there is for this tcase)
You'll need:
-NV273 Transfercase
-Connector for shift motor (available through Motorcraft)
-Connector for encoder motor (available through multiple sources)
-Shift module and grey + black connectors (2008 F250 PN-8C3T-14B205-AB)
-Mode select switch and connector
-2 12V automotive relays
-small aux fuse panel (I use this rather than trying to find empty fuses in the van)
The tcase has the two wires from the shift motor going to the two relays (we mount relays under the hood, left side of inner fender). Then 6 wires from the encoder motor to where the shift module is located (inside the van).
The switch will get a dash light wire, two wires to the control module and a ground
The shift module will need these inputs:
-12V+
-Ign 12V+
-GND
-VSS (see van's wiring diagram for easiest place to tap into this)
-Neutral indicator (essentially, the module is looking for a ground when in park or neutral)
-Brake switch
The module outputs to:
-4wd hi light (this wire goes to ground when in 4 hi)
-4wd lo light (this wire goes to ground when in 4 lo)
-6 wires to encoder
-2 wires to the vacuum hub solenoid
-2 wires to the mode select switch
-2 wires to control the relays
The vacuum hub solenoid has the two inputs from the shift module plus a 12V+ source. You "T" into the vacuum line running across the top of the firewall (it goes back behind the heater to a vacuum reservoir) and run the vacuum line to the solenoid. The other line splits to the two hubs. check valves before the solenoid and after the solenoid but before the split to the two hubs are needed (just like Fseries set up).
That's all there is to it.
Micheal: Brilliant as always. Hopefully you have the time and the inclination to answer my specific question below.
My New Year's resolution was to have no more broken stuff. The Dakota, the Bronco and even the Corolla are all or are all nearly dialed, so I am stoked to start working on my van again.
Here's my specific question. My 2002 E350 7.3PSD Ext. van has the Borg Warner 1356 in the manual shift version. It slipped out of gear within the Salem-Kroeger warranty period and they replaced the shift forks. And it worked for a year or two, but later started happening again. I believe that the linkage is putting stress on the shift forks as the van body twists and wears down the plastic shift fork tips.
My 1995 Bronco and my 1993 Bronco before that also have (had) the BW 1356 but in the electric shift version - which I never ever had any problems with. I can get a used BW 1356 electric shift for relatively little money, but my desire is to use the 2007 F250 vacuum hubs which Salem-Kroeger installed (I have the 2007 F250 oem shop manual) by installing all of the requisite gear which you mentioned in your excellent post above.
The tail shaft on my van's originally 2x4 4r100 transmission was "replaced/modified" to attach to the BW 1356. Can I / should I just install a NP 273 electric shift instead of a BW 1356 electric shift? That way I would be doing the full conversion you mention in your post above, rather than doing some modified version of the Bronco-type BW 1356 electric shift with the 2007 F250 vacuum hubs?
I know I am asking for allot of free advice here. And I will respect you if you think I am asking too much.
02-21-2019, 12:13 PM
#94
Auto hubs are essentially a separate system from the t-case...and don't overcomplicate things....it's a very simple system. Hubs, vacuum lines, solenoid, check valves, that's it. ESOF modules can control the vacuum hub solenoid as in the case of the 2008-vintage NV273 controller but all that's going on is that a "valve" is being turned on and off when 4wd is engaged. Many ways to get that sort of thing to happen.
On rigs with manual shift tcases, we've set up the auto hubs by just plumbing in the solenoid and wiring in a switch (technically, the switch triggers a relay which then handles the load of the solenoid). If you wanted to get really fancy, you could trigger the relay using the 4wd indicator switch on the manual shift tcases...
In cases where we're doing stand alone auto hubs, we've used the vacuum solenoid from the F150. It's a continuous duty solenoid that is basically just on or off. Two wires (power and ground), two vacuum lines (1.From van vacuum source, 2. To hubs). If you're going the route of the NV273, use the F250 solenoid since that's what the whole system is designed to work with and behaves a little differently than the continuous duty part.
I don't have a lot of experience with the BW tcases. I'm not sure what ESOF module they use and I've not looked at a wiring diagram for one. They're probably very similar to the NV273 controls-wise though. Seems to me like swapping in a BW would be a simple task in your case.
02-21-2019, 12:42 PM
#95
10-4. Thank you mgmetalworks !
Your design and implementation is always top notch.
In comparison, Salem-Kroeger ran the ESOF hubs off the serpentine belt driven vacuum pump on the 7.3L, giving an uncontrolled vacuum which sucked in and broke my hubs.
I notice that the F150 vacuum solenoid you use (and what is specified in the 2007 Ford F250 oem shop manual) supplies an initial burst of vacuum to suck in the hubs to engage them, and then drops to less vacuum to keep them engaged.
An electric shift BW 1356 is easy and cheap and, in my case, a direct replacement for what is in the van now. And I have the 1995 Ford Bronco oem Electrical and Vacuum Troubleshooting Manual, so even I can probably figure out and duplicate the wiring for the electric shift BW 1356 for the van.
Thanks again, big time!
02-21-2019, 02:44 PM
#96
mgmetalworks: OK I was wrong. Crawling around under the van and the Bronco and comparing the two, I see that the Bronco's BW 1356 Transfer Case has a flanged output shaft while the van's BW 1356 Transfer Case output shaft is a spline-type shaft.
So Salem-Kroger modified the tail shaft on the BW 1356 in the van to make it a spline slip yoke to accommodate the driveline's extension/contraction as the rear differential moves up and down.
Looking at the 2002 Workshop Manual for the Excursion, F-Super Duty 250, 350, 450 550 Volume 2, the NP Transfer Cases use a flanged output shaft to connect to the driveline, just like the Bronco.
The Bronco and the F Series Super Duty's use a mid-driveline splined slip yoke to create the necessary extension/contraction.
So buying an electric shift BW 1356 is not going to be an easy replacement for the failed manual BW 1356 in my van.
MG, what do you use on your 4x4 van conversions?
Do you use the normal flanged output shaft from the NP Transfer Case and then just toss the E-Series driveline and have an F Series type mid-driveline splined slip yoke driveshaft made for the van?
Or do you have the output shaft from the NP Transfer Case modified to a slip output shaft and just shorten the E Series driveline and use it?
Sorry to be back so soon with more questions, but I trust your design over Salem-Kroger.
Finally, will the NP Transfer Case say a NP 273 electric shift bolt up to the output of the 2002 E350 2x4 4R100 Transmission without modification?
And do you sell NP Transfer Cases or can you recommend a good source for them?
02-26-2019, 03:59 PM
#97
Fox Shocks par number for rear shocks?
Anyone got the correct part Number for the rear Fox 2.0 shocks post lift.
Thanks
02-26-2019, 04:00 PM
#98
Fox Shocks part number for rear shocks?
Thanks
02-26-2019, 05:00 PM
#99
Thanks
I'm running Fox 985-24-061 with MG 4x4 conversion and Agile rear leaf springs (~6" lift).
I bought my shocks and had them custom valved by Agile Off Road in San Diego. Custom valving didn't cost a lot more and definitely improved the ride on and off road.
2008 E350 RB 6.0 - Bullet Proofed, MG 4x4 Conversion
2009 E350 RB 5.4 - Camburg Kit (Sold)
03-01-2019, 01:56 PM
#100
4x4 Expedition Van Project progress...
My MG Metal Works project is coming along really nicely, and I must say how much I am enjoying doing this... neighbors maybe not so much...
https://www.facebook.com/4x4-Expedit...1379148121143/
