Regarding the ERA -- I found a device that is much cheaper than the Abbott and works just as good -- and is way more user friendly.
eBay link below...
UNIVERSAL SPEEDO SPEEDOMETER CORRECTOR
I emailed back and forth with the guy a bunch and he is solid -- this ERA does output a square wave -- which our PCM doesn't like -- but adding a simple capacitor in parallel with the output from the speedometer corrector converts this wave into something our PCM handles...
Here's the message from Gene, the seller/designer:
New message from: gkgoodcheapparts
Happy to help. Most Ford PCM's need an AC signal on the OSS input (even though they'll take square on the CKP and CMP inputs, go figure!). Usually you won't need anything complicated, just a capacitor to couple the square source to the PCM. It makes a funky-looking waveform but it's true AC and the PCM's will generally accept it. The cap wants to be 0.1 to 1 uF (microfarad) and rated at least 25V. Something like these should work fine:
https://www.ebay.com/itm/384159595579
Best Regards,
Gene K
I can verify that this speedometer corrector works -- and it really is simple to use!! There is an up-button and a down button -- you choose the conversion ratio that you need -- and voila -- you're up and running.
You can figure out your conversion ratio using a spreadsheet I think I've linked previously in this thread -- but I'll link it again here since it seems relevant:
https://docs.google.com/spreadsheets...it?usp=sharing
You'll need to copy the spreadsheet to make your own edits -- but it's all there.
You can even have someone adjust it on the fly using a GPS speedometer until you get it to match -- no way to do that with the Abbott ERA.
This isn't to bash on the Abbott ERA -- I've spoke with those guys and they're great. I just really don't like that you need to contact them to get the dip-switch code for your ratio -- it's just poor design IMO.
