Old 11-03-2022, 05:22 PM   #1
E350's Avatar
How to remove these pins?
The below photos are of "pins"/"fasteners" installed by Sportsmobile Indiana in a Sprinter cargo van conversion. They hold the vinyl covered panels which surround the windows to the wall.
Also can someone recommend a source for the light gray panel which was used in this build?
Pins to hold down the Vinyl panels.jpg   Pins to hold down the Vinyl panels photo 2.jpg
Old 11-03-2022, 06:39 PM   #2
E350's Avatar
Let me answer my own question. The button you see is merely a cover which may be popped off to expose a Philips head wood screw:
Old 11-20-2022, 11:30 AM   #3
I don’t believe those are wood screws. I have these and they are screw snaps. They are screwed in and the head is a receiver for the snap. Sportsmobile uses snaps that can be covered with a material, be it fabric or this vinyl material.
You can actually buy these screw snaps in marine supply stores or Amazon. They come in very handy. I used some to secure my insulating curtain, behind my cab seats, along the side edges to help seal off the cab from the living area. I also used four to secure my bath mat to the inside of my shower enclosure door, when not in use.
You can probably contact Sportsmobile to ask where they source their grey vinyl material from so you can get an identical replacement. Those panels should just unfasten from the wall. Then you can staple new vinyl material to the thin plywood backing. There should be a layer of thin foam between the plywood and the vinyl.
EDIT: I did some searching and I think what they are using is something called Dura Snap. They are like the screw snaps, but they have the covered snap buttons in various materials. The screw is a Philips head screw that holds the snap receiver like a washer. You can find them here:
https://www.amazon.com/Dura-Upholste...99333684&psc=1
grinnelljd is offline   Reply With Quote
Old 11-20-2022, 01:09 PM   #4
Mer1039's Avatar
Here is a video link that shows making your own covered snap buttons if you want to use your own material/fabric.
Ron & Barb - 2016 SMB Sprinter, 6 cyl, 144", 2WD, high roof
Mer1039 is offline   Reply With Quote
Old 11-20-2022, 03:50 PM   #5
Actually it looks like the OP is asking about plastic "snap caps". My van uses both these in a few places as well as the fabric-covered "screw caps" in others.
More info here:
Snap-Caps - Screw Caps, Screw Covers | Pro-Dec
