Old 10-22-2011, 07:52 PM   #1
charlie56's Avatar
How to remove air vent blades (Ford)
Anyone have an idea how to remove the air vent blades in the front dash?
I would like to take them out to clean them and vacuum out the dust that has been building up inside the ductwork. Anyone with a body service manual that explains how they are attached? I don't want to just pry them if there is a hidden screw or clip somewhere.
... Charlie
KZ6T
Old 10-23-2011, 04:43 PM   #2
scatter's Avatar
Re: How to remove air vent blades (Ford)
According to my service manual, the vents are part of the dash and come out with the dash. Obviously, they are removable as they are a movable part. I've cleaned mine by putting the fan on high and selecting vent. Then I use an air compressor to blow air into the vent. It really cleans out most of the dust. The compressor blows the dust loose and the fan puts it back in your face afore it goes very far into the vent ducting. This is best done before you clean the rest of the interior....
If you come up with a way to pop out the louvers without damage, let us know.
Scatter
2007 RB50, 6.0
K1WGB
Old 10-23-2011, 05:05 PM   #3
charlie56's Avatar
Thanks
I will try that next time BEFORE I clean the interior.
If you look closely there are two tabs on each side of the assembly. Depressing them doesn't seem to do anything though.
... Charlie
KZ6T
Old 10-23-2011, 07:25 PM   #4
Good idea. Do you close all but one vent so there's more air pressure for the one vent that you are cleaning at a given time?
Old 10-24-2011, 08:35 AM   #5
scatter's Avatar
Haven't done that Herb, but not a bad idea. Moab last week put a bunch of dust in there so I'll give it a try.
Scatter
2007 RB50, 6.0
K1WGB
Old 10-24-2011, 03:08 PM   #6
If Scatter thinks HIS vents are full of dust, he should see the vents of the van that was BEHIND him!!!!
Bill
(BTW, that would be mine....)
NO2B
Old 10-24-2011, 10:17 PM   #7
scatter's Avatar
Bill
But you look so good in Utah red....
Scatter
2007 RB50, 6.0
K1WGB
Old 06-02-2012, 01:44 PM   #8
Bbasso's Avatar
the vents come out... from the back side of the large panel.
Rob.
Current:
And had three other E350s...
Old 06-03-2012, 11:45 AM   #9
yvrr's Avatar
I haven't tried this but, in addition to closing all but one vent at a time, you might get a large rag and put a small hole in the middle of it and then get it thoroughly wet. Put that over the vent to be cleaned and blow air through the hole. The wet rag MIGHT catch most of the dust.
Jack
'01 Ford EB50p Quigley 4WD
Old 06-26-2012, 12:06 PM   #10
WVvan's Avatar
Gently pry up at the bottom of the air vent with a flat blade screwdriver.
Pops right out.
NOTE: You don't have to remove the front of the dash to do this. It just happened to be on my workbench at the moment.
Open the pod bay doors Hal.
WWW.WVBIKE.ORG
