Old 09-23-2017, 03:07 PM   #1
Glider's Avatar
Not A Windshield Leak, But...
The History:
Some time ago, I started a thread about a known Ford van issue with leaks at the body seams around the windshield. That thread can be found here:
http://www.sportsmobileforum.com/for...ers-18780.html
At the time, I had noticed occasional moisture on the driver's side floor, and I figured that it must be related to the windshield/body seam issue. A lively discussion followed; a number of folks reported tracking down and resolving variations on this theme. Forum member JWA has been really helpful to numerous folks in this regard.
In the meantime, I still had not tracked down the source of my issue. It was a dry summer, and when it's not raining, why worry, right? But winter is coming, so...
...I tracked it down today. It is not the windshield issue, but it is something that I'm guessing may be affecting more vans than mine.
The Location:
Inner fender.
The Issue:
Ford puts a hole through the inner fender, and seals it with a grommet. That's good, because when it rains, water sheets down that surface, and the hole opens up to the inside of the van, behind the footwell kick plate.
Here's a photo of my passenger side front door. I have circled the grommetted hole in red:
Closeup:
That hole is perfect for running wires from the engine compartment to the interior of the van--and that's exactly what SMB did on my driver's side. Through that hole, I have a 6AWG wire running from my chassis battery to the wire separator under the gaucho, as well as two control wires for my Starcool system.
Here's a photo of the driver's side of my van, showing the three wires penetrating the hole. No grommet. Instead, a poorly-executed silicone job. You can also see the red 6AWG wire inside the van, dropping down into the footwell, in the right bottom corner of the photo. (This is with the kickplate removed.)
Closeup, showing messy attempt to seal the hole with silicone:
When I run water against the outside of the van, it sheets down the face of the inner fender, and seeps into the van along the red battery cable, because that hole is not properly sealed. SMB, I love y'all, but this is not good.
The Cure:
After a very helpful chat with my main man 86Scotty, I am thinking of doing the following:
1. Remove and replace the 6AWG battery cable with a larger gauge wire. I was going to do this anyway. The new wire will not enter the van through this hole. I'll run it under the van, and up through another existing hole under the gaucho.
2. Pull the two black wires, and re-route them through existing holes in the footwell instead of the hole in the inner fender.
3. Cuss a bunch as I'm cleaning up all of the existing silicone, because it is dang difficult to access that spot, and SMB should have known better.
4. Seal the hole with a new grommet.
5. Never run wires through that location again.
Has anyone else done something similar? Thoughts?
2006 SMB EB45ish.
5.4L, QuadVan 4x4
Ready to Rumble!
Old 09-23-2017, 03:28 PM   #2
ShuttlePilot's Avatar
That's some very nice detective work there. I don't think I have any wiring going through there on mine but I'm sure going to check. If they did it on one van.......
-Eric
2005 SMB RB 4x4 6.0 PSD
A rocket on the pad is safe,
Old 09-23-2017, 03:50 PM   #3
Any easier to reach that spot with the fender liner out? Removing that small piece of plastic in the inner fender gets you access to that area up in there... I just don't remember how far up you can reach. Might be worth a shot though, the fender liner is easy to remove.
Old 09-23-2017, 04:24 PM   #4
Glider's Avatar
Thanks, MG. Yes, Eric and I contemplated the same thing. Unfortunately, doing this does not provide useful access. Pulling the fender would. After I remove the wires, if I can't get the area clean enough to be able to seal it up with a grommet, I think that's what I will need to do. But I think I can make it work by reaching in from the door opening. One thing's for sure: I will be happier once I am no longer running wires through that hole. Just not a good place, given how exposed it is to water.
2006 SMB EB45ish.
5.4L, QuadVan 4x4
Ready to Rumble!
Old 09-23-2017, 07:25 PM   #5
larrie's Avatar
If you decide to pull the fender be sure to put several alignment marks on both the body and the fender. The marks will help get the fender back in the same place.
Larrie
Old 09-23-2017, 08:17 PM   #6
Glider's Avatar
Thank you, larrie. I have zero experience with body work, so advice in this regard is much appreciated.
Today, I removed and re-ran the two smaller wires. For the battery cable, I need to acquire some 2/0 to replace it with. Once I have my new wire, I'll be able to pull the battery cable out of there, and then seal the hole.
Regarding my new wire: It looks like I could go with SAE J1127 welding wire, with a choice of EDPM, Polyethylene, Neoprene, or PVC insulation, or I could go with UL1426 tinned copper marine cable, with a choice of Vinyl or PVC insulation. Anyone have any thoughts on the pros and cons of each?
2006 SMB EB45ish.
5.4L, QuadVan 4x4
Ready to Rumble!
Old 09-23-2017, 09:45 PM   #7
larrie's Avatar
I used welding wire with EPDM. Welding wire is incredibly flexible compared to other types of wire.
Let me know if you need a second set of hands.
Larrie
Old 09-23-2017, 10:03 PM   #8
Glider's Avatar
Thank you, larrie! I might take you up on that offer...fishing 2/0 cable through tight spaces is definitely easier with two sets of hands. Where did you get your welding wire? Do you have a source for quality wire at a good price?
So far, I've looked at:
1. SAE J1127 welding wire/EPDM insulation from Crimp Supply via Amazon:
https://www.amazon.com/gp/product/B0...HFZHO49U&psc=1
$81.41 for 25 feet
2. UL1426 marine wire (Type 3 stranding)/PVC insulation from bestboatwire.com:
2/0 AWG Battery Cable Tinned Marine Grade Wire Red by the foot
$128.75 for 25 feet
3. UL1426 marine wire (Type 3 stranding)/PVC insulation from Fisheries Supply:
https://www.fisheriessupply.com/anco...-battery-cable
$146.45 for 25 feet
I don't want to throw my money away...
2006 SMB EB45ish.
5.4L, QuadVan 4x4
Ready to Rumble!
Old 09-23-2017, 10:30 PM   #9
rallypanam's Avatar
Why not pull the wire through the firewall, and lose the half assed hole through the grommet entirely?
rallypanam is online now   Reply With Quote
Old 09-23-2017, 10:41 PM   #10
Glider's Avatar
That's pretty much what I am doing. I've re-routed two of the wires already. I'm going to replace the third wire with a larger one, so I'm going to wait until I have the larger wire. Once I have it, I will run it in a new location, and not through the grommet hole. Then I will seal up the grommet hole with a new grommet, and all will be well again.
I don't really want to drill a hole in the firewall to run the new wire. I'm planning on running it down through the floor of the van, along the frame for a short distance, then up into the engine compartment. That's what I did with the other two wires, and I'm perfectly happy with that approach.
2006 SMB EB45ish.
5.4L, QuadVan 4x4
Ready to Rumble!
