Old 02-05-2018, 08:50 PM   #51
JackTuppVan's Avatar
Rock Slider Engineering
Ford Full-Size Van/Sportsmobile Step-Slider Installation Instructions
http://www.rockslideengineering.com/.../id/1469045176
Robust rocker guard with automatic step
US 8833781 B2
patent info here...https://www.google.com/patents/US8833781
2007 E250 Super Duty cargo
1988 Toyota Van 4x4 5-spd
Old 03-06-2018, 07:31 AM   #52
RSE Side Steps
I just received and installed the RSE steps on my 2002 Traverse to modern surf van project. Although they weren't technically making them anymore, they did make me a set. Im super happy with the build quality and although the install can be a little tricky, theyre a great solution, IMO
mfj20th is offline   Reply With Quote
Old 03-06-2018, 07:51 AM   #53
Are you willing to share how much they cost you? Also how are they for getting out of the barn door?
Nrobert10 is offline   Reply With Quote
Old 03-06-2018, 10:32 AM   #54
It was a little over $2K trucked to SoCal
Old 03-15-2018, 11:54 AM   #55
AMP modification update
After multiple calls and conversations with AMP directly and their supplier who does the actual step extrusions, both are completely unwilling to help with providing steps of the appropriate length..., (The longest AMP will provide is 85”). We need 96” for our vans to run the full distance from from to rear wheel... very disappointing and I’m certainly not impressed with either company (I’m in the aluminum extrusion business and know how incredibly easy it would be to simply push out a couple sections at the needed length, they just won’t do it). Consequently, I will be splicing/welding sections together now... will update forum when finished!
Dummyfatpigpoo is offline   Reply With Quote
Old 03-15-2018, 01:20 PM   #56
Originally Posted by Dummyfatpigpoo View Post
... (I’m in the aluminum extrusion business...)...
sorry to derail here but....
Can you private message me your contact info? I've been looking for an extrusion vendor for a few product ideas I want to develop.
Old 05-27-2018, 01:25 PM   #57
Any update? Did you figure out how to get the Amp steps to mount to the van? What model of steps did you get, what is the vehicle the steps are intended for?
I still need to do this if I can find the right steps.
cthayn is offline   Reply With Quote
GIL
Manoel Brazil
At-At
Dirk/co
