03-24-2014, 03:24 AM
#31
Re: My Big Stuck
Geoff, nice wriite up. Glad it all worked out. Looking back, do you think you'd have gotten stuck had you been in 4wd? And perhaps aired down?
Phoenix Arizona
2008 E-150 5.4L w/Quigley. Vangator II Wheelchair lift,
03-24-2014, 10:37 AM
#32
Re: My Big Stuck
From a similar situation later in the trip where I was able to continue forward with 4x4, momentum, and lots of throttle, I'd wager 75% chance of not getting stuck if I'd actually been in 4x4 like I thought I was. 25% chance of getting super stuck. In my later successful playa mud situation, it felt like driving on sand, where if I kept my speed up with lots of throttle, I seemed to "float" somewhat and keep moving (even though I still had very deep tire tracks).
I haven't experimented with airing down real low (say, 20 PSI) in mud situations, so I personally have no idea if that would help.
-- Geoff
03-24-2014, 10:38 AM
#33
Re: My Big Stuck
Originally Posted by geoffff
In this case I was already down to 35 PSI for washboard roads, and no, I didn't try airing down further to sand PSIs.
In my experience, it's definitely not enough. On washboard, you can drive with 24-28 PSI, it will be much more comfortable. In soft sand, it makes a huge difference airing down to 15-18 PSI, even more if your're stuck. The next time, try it, you'll be surprised of the difference... ;-)
03-24-2014, 11:23 AM
#34
Re: My Big Stuck
Definitely makes a huge difference...assuming you do not separate the tire from the rim.
03-24-2014, 01:21 PM
#35
Re: My Big Stuck
Yes, I love low PSI in the sand. I often go a bit below 20PSI, but I really don't want to break a bead. I've studied those videos about reseating beads with flammable gas :O but I don't really want to try it
-- Geoff
03-26-2014, 08:14 PM
#36
Re: My Big Stuck
Never broke a bead in soft sand or mud...
03-27-2014, 12:26 PM
#37
Re: My Big Stuck
I've done the engine starter fluid thing during a SMB rally "how to" fair but don't carry it. I haven't broken a bead yet but I do carry a heavy-duty ratchet strap which, I hope, will solve the problem if it every comes up...
Jack
'01 Ford EB50p Quigley 4WD
03-27-2014, 08:59 PM
#38
Re: My Big Stuck
How do you use the ratchet strap to reseat a bead?
Test test test, this is where the signature goes
03-27-2014, 09:11 PM
#39
Re: My Big Stuck
Strap around the circumference, and tighten it which will help force the beads towards the edge of the rim. The strap by itself won't be enough you will still need a high volume compressor or air tank. Sometimes removing the valve stem core will help let air in more quickly and can help seat the bead. Once the bead is seated, reinstall the valve stem core and inflate normally.
01-10-2020, 12:56 PM
#40
If not the old either and match work but only as a last case scenario! You happen to find the only mud hole in Baja. Ha Just kidding rains down there are brutal!
This post intrigued me because I do happen to have an exhaust jack! Although I feel the van would be too heavy I have kept it as a conversation piece. I pull it out and raise my Jeep to non believers!
