Originally Posted by Damian
Ok you guys got me convinced to go the route of a 12V cooler/fridge.
I still want a cheap way to use a small microwave without spending $1000 bucks.
Damian: Both your fridge and microwave have data labels with input power (watts) or current (amps) on them somewhere. The smallest microwaves are 700W output power, usually about 900-1000W input power. You can run these with a 1000-1500W inverter no problem. If you don't have house batteries, then you will need to run the alternator (engine) when using the inverter or else your starting battery will die very quickly.
If your microwave is house-sized (1000W-1200W output power, 1300-1500W input power) even a 1500W inverter will struggle with just a starting battery unless you are running the engine. Running one of these off of a starting battery (if it works at all) will kill the battery in a very short time measured in minutes, not many minutes.
A 700W microwave is $59-$69 all over the place, Wal-Mart, Target, Best Buy, etc.
A 1000W-2000W inverter can be purchased for $300-$400 these days (some models). These typically won't have the shore power relay or charge your batteries, but they will run appliances with enough battery power.
http://www.amazon.com/s/ref=nb_sb_noss_ ... x+inverter
