Old 07-24-2018, 01:33 AM   #11
Pschitt's Avatar
Thanks to all of you guys.
Originally Posted by Twoxentrix View Post
... Have to say though, I would hate see you have to make use of it.
It could likely happen as I'm gonna visit Iceland from mid August and there is a lot of water crossings up there. Anyway, the cyclonic pre-filter will permanently reduce all the dust/sand reaching the air-filter, which is good as VivaLaVida often drives on dirt/gravel.
Old 07-24-2018, 04:18 AM   #12
schluchtenflitzer's Avatar
I am impressed Claude!
Very nice and well done. I am also thinking about doing that with my 7.3 as soon we are back from africa. What diameter is the pipe you used? Thats one of my biggest goals, not to go to small for this huge engines
www.Dieda-unterwegs.net
schluchtenflitzer is offline   Reply With Quote
Old 07-24-2018, 07:17 AM   #13
TomsBeast's Avatar
Very nice! Professional looking job. I've never plastic welded before, have seen the equipment popular with sportbike riders for repairing factory plastics. What is it and where do you get the tube and flat stock, filler rod and and welder?
Old 07-24-2018, 08:37 AM   #14
djbonsu's Avatar
Nice work and clean install!
2000 E350 Cargo PSD w/ UJOR 6" Lift
djbonsu is offline   Reply With Quote
Old 07-24-2018, 09:02 AM   #15
Pschitt's Avatar
Thanks Didi! Hope you're still enjoying Africa!
Diameter of the upper pipe is 110 mm. The equivalent surface is larger than the original opening in the airbox. Of course, this upper pipe has a smaller section than intermediate fender part and airbox's new flange which are much larger. Actually, the smallest section is the cyclonic filter itself but according to the manufacturer Donaldson, its 100 mm diameter is definitely enough for à 6 liter turbodiesel engine.
Well, here in Switzerland, i got the pipes from building suppliers (those are used for drainage and flowing) and flats from a plastic company. To weld it, you need a hot air welding gun with PE welding rods. You can find it online (amazon or other supplier for less than 150 US$. You just need some training as it's easy just to stick it rather than really welding it with enough depth. But after some tries, it's not that difficult.
And to bend the flats, just put it in the sun for 15 minutes and it's easy to get in shape.
Old 07-30-2018, 05:52 AM   #16
Awesome build!!!
Twintreiber247 is offline   Reply With Quote
Old 07-30-2018, 06:51 AM   #17
Great job and looks very clean.
greatwhite1 is offline   Reply With Quote
Old 07-30-2018, 08:39 AM   #18
Pschitt's Avatar
Thanks again guys.
Old 07-30-2018, 02:02 PM   #19
mk216v's Avatar
Nicely molded to the fender Claude!
A vehicle’s worth is not what you put into it, but what it put into you.
2019 F350 SuperCrew flatbed composite camper
2018 Transit 130WB MR EcoBoost (SOLD)
2010 E350 RB V10 Cargo "unicorn" (SOLD)
2007 E350 4x4 "VANdiana Jones"(SOLD)
mk216v is offline   Reply With Quote
Old 07-30-2018, 02:17 PM   #20
Pschitt's Avatar
Well, if you take a close look, it's not perfect. But at least, it's fully functional.
