Old 04-19-2012, 07:38 PM   #1
Zeta's Avatar
EZ Rack, Rotopax, Maxtrax Oh My!
Worked on installing the EZ Rack I got from Rock Slide Engineering today. Very lightweight and EZ to install. Also added an extra bracket--the white part--to support the Maxtrax traction ramps I bought. Plus, I thought it would be wise to carry extra fresh water and diesel, so I bought some of the exceptional Rotopax tanks and mounting hardware. I was blown away by the quality of these American made goodies. I can now carry four extra gallons of water and fuel. Only the fuel tank is shown as the water tank is on backorder and will be here next week.
Shows how the Rotopax tanks can be stacked.
Very happy with the installation--a few adjustments needed, but the real week link is the flimsy Aluminess swing away arms. Gonna fix those by installing spherical bearings in the arms.
Here's a video showing the EZ installation--remember, the camera adds ten pounds:
[youtube:tzlqamj9]
'06 RB50 SMB Diesel
https://www.tomsinclair.net
Old 04-19-2012, 11:09 PM   #2
Ultrasport12's Avatar
Re: EZ Rack, Rotopax, Maxtrax Oh My!
That rack is very cool even if it is ten pounds lighter that it looks in the video.
2008 Ford E-350 V-10 EB
Transformer Interior
2004 F-350 Dana 60
Old 04-19-2012, 11:37 PM   #3
Zeta's Avatar
It's actually very light. Made out of aluminum.
Z
http://www.tomsinclair.net
'06 RB50 SMB Diesel
Old 04-19-2012, 11:55 PM   #4
BIGVANS's Avatar
Did you make the MAXTRAX bracket or does Rockslide have it available?
2003 Ford E-350SD 4x4
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Old 04-20-2012, 12:03 AM   #5
Zeta's Avatar
I made it. Needs some work though--it's too flexible.
Z
'06 RB50 SMB Diesel
Old 04-20-2012, 05:55 AM   #6
Checked out your website, you do great work!
What size tires on your SMB?
carl
2010 SMB
Old 04-20-2012, 02:45 PM   #7
Tom, is there a way to lock it down and is it designed for the rotopax? Oh...and how much for the rack by itself?
Old 04-20-2012, 05:34 PM   #8
Zeta's Avatar
The Rotopax have locks built into the handles--I used one to hold the Maxtrax in place--and I rigged up a bicycle cable lock to lock the EZ Rack to the spare tire carrier. It was designed with Rotopax in mind--they are made next door and RSE is a dealer--but anything could be mounted to them. The rack is about 6.5" deep.
http://www.rockslideengineering.com/ind ... &Itemid=56
The full rack is like $400, but you can also buy just the tire clamps and strap to do whatever you'd like.
It's also very light. My bad shoulders make it look heavy in the video, but that's not the case.
Tom
'06 RB50 SMB Diesel
