Old 05-15-2015, 06:25 PM   #21
gcvt's Avatar
Re: My solar installation project...
Originally Posted by 86Scotty
It doesn't' bode well that the velcro has a big picture of a fire extinguisher on it. What gives?
LOL, don't jinx me man!
Greg
New van: 2003 E250 EB10
Old 05-15-2015, 11:14 PM   #22
gcvt's Avatar
Got the Velcro installed on both panels...
And the final UPS shipment I was waiting on all day finally arrived this evening...with no instructions, of course. Anyone know how these work? I didn't know what the OD of the wires would be so I ordered two sizes of these. Turns out the wires are 1/4" OD so I'll be using the Ancor 765000 I can't find anything online about these. I searched "765000" and "Electrical Wire Seal " on the manufacturer's website and it tells me nothing.
Oh, and got the new tires put on today. Yay.
Greg
Old 05-16-2015, 12:30 AM   #23
They are pretty simple. Drill a hole where you want the wire to pass through the roof, push the body of the connector through, put the matching flat nut on the inside. (if it's not flat where you drill the hole you might want to put some sealer around the outside first) Choose the rubber seal that matches the wire size. Put the big nut on the wire first, then run the wire through the seal and the connector to the inside of the van. Screw the nut down on the tapered part of the connector and tighten until it compresses the rubber against the wire. That's all..................
Old 05-16-2015, 12:32 AM   #24
Viva's Avatar
I don't think there is anything too different about the Ancor ones (although I haven't used theirs yet specifically), so maybe you could look up electrical "cable gland" and find a diagram that would be helpful (I usually see them called glands).
I've looked for butyl tape "locally" in the past and never had much luck. I think it's too old fashioned (too bad as it rocks). I now always mail order it (not that that helps you now).
Old 05-16-2015, 01:27 AM   #25
gcvt's Avatar
Thanks guys. The other pair I bought came pre-assembled, but since I'll be returning them, I didn't want to open them up to see how they were set up. I'm familiar with bulkheads from my saltwater fish tank days, so I thought I'd get this right off the bat.
Viva, I was just about to PM you about this since your name came up a few times when I searched "Ancor" on the forum
I'm guessing I need to be using the white piece since this thing is meant for .24-.47 and I'm at .25". Tried cramming that thing in there but it doesn't want to go. Might need some lube
I'll try again in the morning. Getting new tires put on and waiting for UPS all day made me tired.
Greg
Old 05-16-2015, 02:04 AM   #26
gcvt's Avatar
Oh, just a heads up. Renogy says these panels are 41.3" x 21.3". That's not really accurate. The two panels I got are different sizes so I've had to make slight adjustments for that. One panel is 41-3/4" x 21-3/8" and the other one is 41-3/4" x 21-1/2". No big deal, just FYI.
Greg
Old 05-16-2015, 09:46 AM   #27
Got a Walmart nearby? They seem to carry Buytl tape.
http://www.walmart.com/ip/29764312?w...421312&veh=sem
Old 05-16-2015, 10:35 AM   #28
gcvt's Avatar
Not really close. There's one in Oakland and another 45 miles South. I'm gonna head back to West Marine and see what they have. They've got to have something suitable for this.
Got the Ancor thing figured out. It already had one rubber grommet installed, but it was black and super thin, so I didn't even notice it.
Greg
Old 05-16-2015, 07:31 PM   #29
gcvt's Avatar
Got the panels mounted today and the wires run inside the van. Feels weird drilling big holes in a perfectly good roof. I'll get started on the wiring tomorrow.
Once I got these mounted and wired in, I started thinking I could really use two more of these. Actually, I could fit three more And they didn't fly off on the way home, so that's a good sign I suppose.
Greg
Old 05-16-2015, 09:12 PM   #30
gcvt's Avatar
Look what you started! I randomly looked down at my odometer on the way home from where I installed the panels today, and saw this!
Greg
