Old 03-06-2013, 12:11 PM   #71
audisnapr's Avatar
Re: New SMB Owner: 93 Ford E250 2x4
McMaster-Carr is a great resource. The biggest problem trying to find the name they use on some items - if they call something other than what you call it, searching is useless.
my searching experience has been relatively good. generally I don't know the name of the part anyway, so it takes me a little while to find what I'm looking for but I do eventually get there. If not, then I browse and end up buying other crap I don't need. It's a win-win situation.
Perfect example - I had no idea what the spring clips were called. I started with "tool holder" as my search syntax - wallah, there they were.
4amRacing
audisnapr is offline   Reply With Quote
Old 03-18-2013, 08:31 AM   #72
audisnapr's Avatar
Got storage?
Sent from my SGH-T999 using Tapatalk 2
4amRacing
Old 03-18-2013, 09:43 AM   #73
Really love the onboard computer setup!
My only worry would be spilling a drink in that keyboard! Do they still make those ugly plastic keyboard covers that you could use just while traveling? Or do you take the keyboard down while moving?
Old 03-18-2013, 10:55 AM   #74
SCBrian's Avatar
You've been keeping us in suspense this whole time and then only post one pic of the tire carrier!
2001 E350 V10 Homebrew
My Build Thread
SCBrian is offline   Reply With Quote
Old 03-18-2013, 12:58 PM   #75
audisnapr's Avatar
sorry - that pic was from my cell. Needed some time to save down my point and shoot pics. Without further delay.
4amRacing
Old 03-18-2013, 06:17 PM   #76
SCBrian's Avatar
Great work! Would you do it again or would you buy?
My Build Thread
Old 03-18-2013, 07:18 PM   #77
audisnapr's Avatar
I would def build it. If money wasnt an issue, sure I'd love to have an Aluminess setup... but only after the Quigley install . For me the only way this would ever happen is to call on some fabricator friends to build it for me.
Sent from my cm_tenderloin using Tapatalk 2
4amRacing
Old 03-23-2013, 06:05 PM   #78
audisnapr's Avatar
a few finishing touches
beefy top hinge plate
shaped nylon support/stopper
a couple new overalls
4amRacing
Old 03-23-2013, 07:15 PM   #79
Did you have to pull the hinge bolt and install a longer one? If so how difficult was it to get the bolt out? That is a nice mod. I've seen a few of those break
Old 03-23-2013, 07:51 PM   #80
audisnapr's Avatar
Are you referring to the OE hinge pin? Yes, I had to remove it and replace it with a grade8 7/16" bolt. Removing the OE pin wasn't too bad. Like many others, drilling the bottom of the pin then using an air-hammer seems to get the job done without too much fuss.
I did end up making a few brass bushings for the 7/16" bolt to make up the difference in size with the OE hinge pin which appears to be just shy of 9mm. Unfortunately I never did track down a metric or standard equivalent.
4amRacing
