Old 03-23-2013, 07:57 PM   #81
Re: New SMB Owner: 93 Ford E250 2x4
I like what you have done -
- bronze bushings on the pivots
- secure, overcenter clamps for latches
I couldn't tell from the picture, but is the passenger side taillight blocked completely?
Old 03-23-2013, 09:57 PM   #82
audisnapr's Avatar
the passenger side swing arm assembly is mounted in the same relative location as the spare tire assembly. The lights may be harder to see the because of the box though. I have been doing some research on additional lights to install into the bumper for better visibility.
4amRacing
audisnapr is offline   Reply With Quote
Old 03-28-2013, 12:49 AM   #83
I want a box like that. Nothing to put in it yet but I want it just the same.
stanw909 is offline   Reply With Quote
Old 03-28-2013, 12:14 PM   #84
audisnapr's Avatar
Re: Re: New SMB Owner: 93 Ford E250 2x4
Originally Posted by 86Scotty
Really love the onboard computer setup!
My only worry would be spilling a drink in that keyboard! Do they still make those ugly plastic keyboard covers that you could use just while traveling? Or do you take the keyboard down while moving?
Thanks! Hadn't really thought too much about it. The keyboard covers the drink holders so I'll have to move the keyboard regardless. So far that hasn't needed to happen.
Sent from my SGH-T999 using Tapatalk 2
4amRacing
Old 03-31-2013, 06:47 AM   #85
audisnapr's Avatar
As if the rear rack project wasn't enough for one season...
4amRacing
Old 04-01-2013, 05:24 AM   #86
audisnapr's Avatar
Made a bit more progress. All the tubing is welded up. Top and bottom brackets are welded (bottom not shown in this photo). The big unknown at the moment is the top rain gutter brackets - still toying with a few options.
4amRacing
Old 04-01-2013, 12:13 PM   #87
Silver350's Avatar
Nice job. EMT conduit? The zinc residue seems to indicate that. What diameter?
For mounting brackets, you might consider cutting them out of thin wall square tubing. Then you would have a nicely formed corner to fit along the bottom edge of the gutter and up.
Old 04-01-2013, 12:47 PM   #88
audisnapr's Avatar
yup, 1" EMT. I've done some torch welding on aluminum before, but this was my first attempt at torch welding steel. Using wire coat hangers as my filler rod. So far so good. BTW, this of course is all a test prior to building a roof rack out of 1" EMT. I figured if I can make the ladder happen, I can manage the roof rack as well.
I've looked into the square tubing - I may go that route, thanks. I bought and bent some 3/16" material into the shape I wanted, but am not 100% satisfied with it.
4amRacing
Old 04-01-2013, 01:25 PM   #89
MadScience's Avatar
You're a person after my own heart. Well, as long as you limit it to non-critical stuff and don't start fitting a 4x4 conversion with that method.
Love the tire hanger as well. Even the commercial solutions seem to develop some issues with heavy use.
Old 04-09-2013, 06:50 PM   #90
audisnapr's Avatar
Fabricated, painted and mounted.
uploadfromtaptalk1365554996118.jpg   uploadfromtaptalk1365555007956.jpg   uploadfromtaptalk1365555024703.jpg
4amRacing
