09-29-2008, 10:34 AM
#151
Re: Texture Coated Aluminess
Originally Posted by Greggde
I Texture coated the top of the rear Aluminess Bumper as I was tired of the slippery conditions that prevailed with wet feet or when it was covered with Talc . I t came out real nice and was much less expensive than Line X or the Rhino coating's . I ended up using the DupliColor Truck Bed spray . I also exchanged the incandescent Porch Light for a very low ampere draw LED and finished measuring and laying out the mounting location's for the Tantrum Rock Light Kit .
Greggde
Would love to see some pics/details on your porch light replacement.
09-29-2008, 10:50 AM
#152
Buji ,
I climbed up on it a couple of time last evening and it is much better than it was . I to have 3-M Adhesive Strips on my Ladder , Roof Rack
and the leading edge of my Running Boards . I also had the tape on
the edge of of the front and rear Aluminess Bumper's but removed because I am in shorts 300 plus day's a year and kept peeling my Shin's and Knee's . I purchased two can's and only used one of them so I plan to cross hatch with a second coat ,using 1/4" webbing material after a couple more day's of curing , just for a little additional texture . You can also purchase this material in kits with a roller included but Pep Boy's only had these kit's in Gallons at $99.00 per kit. Enough for a small pick up bed , Can's were only $7.95 each .
Pull up the Dupli Color web site for instructional video's .
Greggde
09-29-2008, 11:11 AM
#153
Led Porch Light
Bronco Hauler ,
Check in my Gallery I took a couple of photograph's in daylight and showed the package with name and model number . I will take some photograph's at night and post them in my Gallery as soon as i am able . I took my Dremel Tool and Flitzed (metal polish) the inside of the light housing and the clear lens for a more reflective surface .
Greggde
PS Just added three more photo's in gallery for you Bronco Hauler
09-29-2008, 09:09 PM
#154
Re: Heat Management
NRL ,
Looks like a clean solution and install , What type , width and length of Insulation did you use and from whom did you purchase the material .
This is on my to do list including the Transmission Pan . Were their any installation issue's with this vented Transmission Pan ?
Greggde
No issues with the Derale Transmission pan. I have the E4OD Transmission. Also order the longer transmission filter since the pan holds more transmission oil and is deeper.
I ordered everything from summit-racing including the adhesive heat shield material and exhaust wraps..
95 FJ80 ARB/Kaymar/Emu
2005 AMG CL65 691hp 875tq
09-29-2008, 09:13 PM
#155
Heat Management
NRL ,
Thank you .
Greggde
10-12-2008, 03:54 PM
#156
Guest
Rotated my tires. 5 tire rotation. Takes about an hour.
10-13-2008, 03:36 PM
#157
Had the oil changed. Went in for brakes due to a squeek, but brakes and pads are fine... maybe I'll go to 17" rims and get to upgrade.
10-13-2008, 07:20 PM
#158
I performed our first oil change over the last two days.
I have to say that having this much ground clearance and using a 5 gallon bucket to catch the oil makes it much easier to change the oil.
.....but filling up most of a 5 gallon bucket with the waste oil is surprising even when you know it is going to be that much....
Greg in Austin
10-13-2008, 09:27 PM
#159
Van: 1
Garage*: 0
*Shown post reassembly
10-13-2008, 09:31 PM
#160
I have that same customization on my garage door.
