Old 06-12-2014, 12:26 PM   #1
Defrost adjustment knob not working
The little dial where I would adjust vent/floor/defrost/ etc is suddenly not working, any thoughts on why this might be?
Thanks,
C.
c7train is offline   Reply With Quote
Old 06-12-2014, 12:29 PM   #2
rallypanam's Avatar
Re: Defrost adjustment knob not working
Thanks,
C.
I had issues on my old van on the fan dial.. corroded electrical connections.
Old 06-12-2014, 12:34 PM   #3
Jeffrey's Avatar
How are your brakes working? When my vacuum pump failed, the ventilation system was wiggy, too. I think the vents use vacuum to operate.
Old 06-12-2014, 02:26 PM   #4
Brakes seem to be working fine.
Old 06-12-2014, 02:41 PM   #5
fancypants's Avatar
Not sure if this describes your situation but this is what happened to me and how I fixed* it: http://www.sportsmobileforum.com/vie...hp?f=2&t=12582.
*: seemed to work as expected for the first couple months after the fix but I'm noticing that when I accelerate it is again sometimes switching to the dash/defrost vents. Haven't had a chance to troubleshoot it again.
KeVan: '06 E350 4x4 V8 "Transformer"
fancypants is offline   Reply With Quote
Old 06-12-2014, 04:33 PM   #6
Jeffrey's Avatar
If your vacuum pump is good (good braking) then check the rubber hoses for the vent mechanisms.
Old 06-13-2014, 04:51 AM   #7
What year, make and model are we working on?
Old 08-24-2014, 08:33 PM   #8
2007 E350 V10
Old 08-24-2014, 10:00 PM   #9
Most likely a rodent has eaten one of your vacuum lines.
Old 08-24-2014, 11:11 PM   #10
Pschitt's Avatar
Could also be the knob itself. Had to replace mine four weeks ago... But check the vacuum hose before to check that there is no leak.
The YURT
MKRyan
Big Backpack
RMAC
