Old 08-18-2016, 05:44 PM   #11
MrHenrietta's Avatar
rallypanam - Know of anywhere I could buy a replacement?
2003 7.3 UJOINT 4x4 SMB
MrHenrietta is offline   Reply With Quote
Old 08-18-2016, 06:07 PM   #12
rallypanam's Avatar
On my old van I went to a high end car audio place and bought this big block with multiple large ports. Worked perfect, almost even better than stock cause you could disconnect individual leads as needed.
Old 08-18-2016, 06:09 PM   #13
rallypanam's Avatar
Or talk to a different Ford dealer. Or John at Agile, he can get you the Ford one.
Old 08-18-2016, 06:20 PM   #14
Thank you so much for the info!!!
Old 08-18-2016, 06:34 PM   #15
rallypanam's Avatar
The car stereo one was something like this, but not exactly:
https://jet.com/product/detail/3d2ab...A&gclsrc=aw.ds
Old 08-18-2016, 06:56 PM   #16
JackTuppVan's Avatar
I'm pretty sure this is the part number Motorcraft WC9329D (Positive Battery Cable) about $100.
You can also replace just the cable end with a "Military Ordinance" battery terminal end.
The military terminals are designed to accept multiple cable leads.
2007 E250 Super Duty cargo
1988 Toyota Van 4x4 5-spd
Old 08-18-2016, 08:44 PM   #17
Originally Posted by REF View Post
I had the same thing on mine, I ended up having to cut the battery lead wires out of the block thing they're pressed into and put some ring ends on them. I found a HD terminal post with an offset post for accessory wires. Not pretty but it works.....
$100 for the Motorcraft part? That's robbery! I have done, and recommend what REF did above. I'm not kidding, I did this to a Toyota the other day and both posts were $2.50 at Wallyworld. They're actually well made too!
$97.50 will buy a lot of gas, or..............
Old 08-18-2016, 10:33 PM   #18
BajaSportsmobile's Avatar
We have them in stock at Agile.
Give John a call.
AgileOffRoad.com
Old 08-19-2016, 08:35 PM   #19
I used this on my V10.
it accepts up to 5 ring terminals, https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 09-03-2016, 01:09 PM   #20
I decided to save a few bucks and build a new terminal. Here's how she looks!
