Re: I need ignition switched 12V power in the back of the va
I am pretty sure that I have the voltage monitor from an old Surepower unit, you could make that work as your voltage monitor, you are welcome to it. The Blue Sea 7610 does have a optional line to drive a status LED, I am not sure about the current capacity, but there is a chance it would handle a relay. The bigger issue, is that it goes into blinking mode when it is in lockout. That would not be good.
If you have a Battery Monitor they will sometimes have extra circuits for alarms, the Xantrex LinkPro has a configurable relay to open or close at a set voltage. I use this for a automatic low power disconnect.
