Old 02-15-2010, 09:10 PM   #1
Angel's Avatar
LED FLORESCENT REPLACEMENT BULBS
I replaced the florescent tubes in my overhead lights with LED tubes. http://rvspecialthings.com/LEDlights.html I bought them in Quartzite. They took the ballast out of each light for me so the LED tubes would work. Then I had a switch added so I can have one tube on or have both tubes on at once.They are nice and bright.
Angel
2000 Isuzu Rodeo V6 4WD
2006 Chalet LTW 15ft. Folding Travel Trailer 14 in. tires
Angel is offline   Reply With Quote
Old 02-15-2010, 10:31 PM   #2
Re: LED FLORESCENT REPLACEMENT BULBS
Nice find Angel! Lots of RVs in Quartzite.
Old 02-16-2010, 06:02 AM   #3
Replacing the florescent lights in the SMB is high on my list, but higher on my list now is getting the hell out of town and down to the desert!
2006 Baja Tan SMB 4X4 EB50 PH 6LPSD
Mohawk Royalex Solo 14 foot canoe (light white-water)
Mad River Kevlar Explorer 17 foot canoe (flat water)
Dagger Royalex Legend 16 foot canoe (white-water)
Maravia New Wave 13.5 foot raft (fishing and white-water)
Ed in Montana is offline   Reply With Quote
Old 02-16-2010, 06:31 AM   #4
That's really awesome... I've got something like this in the queue!
It looks like there are two types, the bulb and the strip. The bulb has fluorescent bulb ends and fits right in the fixture, however you're still powering the ballast and the fixture (although it's easier).
The strip looks like it just has loose wire ends and would be attached to the power source or a switch. Just a guess from the photos, but if you directly wired it you could avoid the fixture sucking up power.
Old 02-16-2010, 08:44 AM   #5
Angel's Avatar
Jage,
I took the ballast out because otherwise the LED bulbs would not work in the fixture.
Angel
Old 02-16-2010, 06:00 PM   #6
Well that makes sense. So you have to rewire the ends that hold the bulb?
Makes my project kind of moot!
Old 02-16-2010, 09:44 PM   #7
Those look great Angel, do you know what they pull in amps? I couldn't find any stats on them.
Dave
Old 02-18-2010, 01:15 PM   #8
Angel's Avatar
Dave,
I called Len @ RV Special Things. He said one 15" bulb that fits into the 18" fixture draws 300 mili amps (.3 amps)
Angel
Old 02-22-2010, 10:21 AM   #9
Thanks...definately the way to go. I will give them a call.
Old 02-23-2010, 10:09 PM   #10
Harry's Avatar
Originally Posted by Angel
Dave,
Angel
Does anyone know the amp draw from the florescent bulb that comes in the fixture is?
Harry is offline   Reply With Quote
