Nothing like having all the part numbers lined up. Here is my conversion, I pretty much copied John & Dana's, so I'll mostly cover the differences:
My switch is
three way converted so I used 3 of the brighter LED bulbs.
On the outside bulb I found corrosion. I don't want to ruin the LED board, so I have to figure out where the water is getting in.
Ah, I think I found the problem- the stock bulb melted the housing AND the lens. Brilliant.
I made a hanger/clip out of 302 stainless welding wire, and a good thing too because I put the wrong board in the first time.
A little electrical tape to keep things from contacting, and we're good to go.
I also bought the cigarette lighter/flashlight ($14.95) from SUPERBRIGHTLEDS just to try it out. It glows a pretty fierce red while charging, and is only about an 1" long. It seems to work great for an emergency light, and if the red LED goes out once it's fully charge I'll be a lot happier with it.
For the inside lights I cut tabs out of one of those plastic collars that holds two gallons of apple juice together at Costco. They were trimmed a bit for each light, as the inside of the lights themselves are not evenly made.
Here are the tabs in place on the rear light. The front was done the same with the other two tabs.
John & Dana, I can't thank you enough for making this as simple as buying the (mostly) same lights as you. Thanks again for the writeup!
