I didn't take photos but here's everything I bought:
Solar Panel
https://amzn.to/36MBsSD
3M VHB Tape
https://amzn.to/2WUVrKv
3M Dual Lock 1" x 10ft
https://amzn.to/2NPwHiL
ScotchBrite Pad
https://amzn.to/32oP4Qz
Coroplast
https://www.homedepot.com/p/Coroplas...896S/205351385
Rubbing Alcohol
Do this when the temperature is at least 60 degrees or warmer.
1. Cut coroplast to size of solar panel
2. Clean edges of coroplast and two strips in center with rubbing alcohol. Clean same places on bottom of solar panel.
2. Apply VHB tape to corplast and affix solar panel. Apply pressure to taped places.
3. Clean bottom of coroplast with rubbing alcohol.
4. Affix 3M Dual Lock to coroplast in four strips.
5. Scuff fiberglass with scotchbrite pad.
6. Clean fiberglass top with alcohol.
7. Remove backing from one strip of Dual Lock and affix solar panel to roof. Continue to remove backing from Dual lock one strip at a time. Apply pressure to strips but be careful to not press solar panel where it is not supported.
8. Don't drive van for 72 hours.
