Old 10-18-2018, 04:53 PM   #1
ghetto fireman's Avatar
Specialty Concepts Solar Controller
Hello All:
This controller was in place when a bought my Sportsmobile, no panel however, I’d like to get it working again. When I changed out my starter batteries, I found wires attached to one battery. I’m assuming that this was for the panel? They terminated inside the penthouse top. Do I just slap on a new panel on the PH top? Looks as if I’m limited on the voltage/amps by looking at the manual.
Thanks
2006 EB SMB " Big Boi “
1967 Toyota Landcruiser FJ-45
1974 Toyota Landcruiser FJ-40
ghetto fireman is offline   Reply With Quote
Old 10-18-2018, 05:09 PM   #2
Twoxentrix's Avatar
Unfortunately I'm not qualified to help on the wiring issue, but if you plan on putting a new panel on I would recommend adding these between the new panel and where it hooks to the wires that go through the Pop-Top to the Controller. that way you can plug in an auxiliary panel when you park in the shade. I have a 100ft cord that allows me to place a 160 watt suitcase panel in the sun. ***Just make sure you plug the cord to the "Y" connectors before you raise your roof - From experience i can share it's a real pain to reach once the top is up!
https://www.amazon.com/MISOL-Paralle...nch+connectors
https://www.ebay.com/itm/Lensun-100W...jVA:rk:22:pf:0
***the panels I ordered came with a detachable Controler that also has the option to attach to a car battery, and ports to plug stuff like cell phones / computers to
Old 12-06-2018, 12:49 AM   #3
Exclamation
Originally Posted by ghetto fireman View Post
Hello All:
Thanks
The + and - “battery” wires from your specialty concepts mark 22 solar controller terminated at your start battery under your hood or the start battery under the van below the passenger seat area?
Hooch
Hoooch
Beni
hildems
