Whoops, ignore my comment in post #8. I mis-remembered, the fuses dangling in the overhead cabinet are for the attic fans. The solar fuse is in a mini-fuse-box identical to the one in Klompen's picture, along with the fuse for the Espar D-5, in the same compartment under our dinette as the inverter-charger. It's labeled as a 30A fuse.
nothing cabled to it and a burnt out 30A fuse
Are you the original owner? How would it burn out if nothing is cabled to it? That's highly suspicious.
they thought I had reversed polarity
That's probably their default answer to all tech support questions. Zamp is notorious for taking an industry-standard plug and swapping the leads to make it just ever so slightly harder to switch to a competitor.
