Old 10-14-2012, 12:08 PM   #1
What is the best tire size with 6" lift ?
I just bought a 2001 E-150 and I want to lifted 6" and I want to put some military tires!
I found some tires 7.50x16 and 9.00x16
But I never heard about the sizes before so I don't know if those tires could fit/safe on the van?
suggestions?
vanvan is offline   Reply With Quote
Old 10-14-2012, 12:20 PM   #2
Re: What is the best tire size with 6
Generally they are not sized in military style. Overall diameter you can go to about 35" with some fender trimming, but with the military being so skinny you might get away without it.
Best to lift first and measure or test fit.
Old 10-14-2012, 12:35 PM   #3
My other concern is if that skinny tire it will be unsafe for the stability
Old 10-14-2012, 01:03 PM   #4
The concern would be more on what the tire is rated for. Have you looked at the tires rating info on the ones you wish to use? It really depends on the weight of your van. An E-150 can't be loaded down as much as the 1 ton E350 so a skinner tire in a D rating should be fine. Looks are up to you but myself I prefer the fat full look under the wheel well. Do you have pics of the van and tires you can post?
Old 10-14-2012, 02:35 PM   #5
This is my e150 and it have 235/75R15
I would like to fit some tires like these
These tires are co-op grip spur 7.50x15 which are 9" width and 32" tall and in my opinion I don't think they are very skinny but they are skinny compared with the 265/75
ImageUploadedByTapatalk1350246480.002317.jpg   ImageUploadedByTapatalk1350246604.964194.jpg   ImageUploadedByTapatalk1350246626.691449.jpg
Old 10-14-2012, 02:51 PM   #6
The other kind of tires that I like are
STA Super Traxion® Light Truck Bias Ply Tires
Old 10-14-2012, 03:33 PM   #7
Gnarvan's Avatar
I think you will be disapointed in the way the bias ply tires handle. Are the first set of tires you showed bias ply or radial?
John
Gnarvan 1992 E350 Clubwagon
2003 BMW R1150GS-Adventure
2013 BMW R1200GS-Adventure
Old 10-14-2012, 04:02 PM   #8
I think they are bias!.. Thanks for your opinion because I don't even know what bias means and that's why I ask for advice!!
Old 10-14-2012, 04:32 PM   #9
Gnarvan's Avatar
There are two basic types of tire construction. Bias and Radial. In my opinion you should stick to radial tires.
John
Old 10-14-2012, 04:55 PM   #10
BajaSportsmobile's Avatar
Where do you live, where will you be driving and what kind of conditions? For example, those would not be good choices for sand, but would be good for mud.
AgileOffRoad.com
Turtle
rafeman
GIL
Manoel Brazil
