Old 03-07-2021, 01:37 PM   #21
Orv
Thanks. It's not as elegant as an Aluminess or MG product, but so far I'm only about $160 into it, including miscellaneous hardware and paint.
N8SRE
Old 03-08-2021, 01:31 PM   #22
Looks good, is it a tow hitch bumper mount rack?
Old 03-08-2021, 04:02 PM   #23
Orv
Yeah. I just didn't assemble the hitch part onto it. Dunno what I'll use those bits for, maybe I'll make a rear step.
N8SRE
Old 03-20-2021, 06:41 PM   #24
Orv
Finished. I see nothing but flaws when I look at the paint, of course...but it looks pretty good from 20 feet away. Since the van itself is a solid 50-footer that works. I'm impressed by how sturdy it ended up. I can grab the rack and rock the van side to side with it and it doesn't flex or shift.
After a bit of struggling, I realized the trick to getting the mounts to fit properly in the rain gutters was to position it with everything loose, clamp the mounts in place, then finally tighten the bolts between the mounts and the rack.
Took the van for a drive to see if the rack was noisy. It isn't to a degree I can detect in an admittedly already noisy van. Unexpectedly, it seems to have altered the airflow over the roof in a way that causes the roof to surge against its hold-down clamps a lot less, so it actually has made the van *quieter* overall. Go figure.
N8SRE
Old 03-21-2021, 03:51 AM   #25
marret's Avatar
Well done, looks great.
Chris
marret is online now   Reply With Quote
