Old 01-31-2021, 10:16 AM   #1
stiggs's Avatar
Send a message via ICQ to stiggs Send a message via AIM to stiggs
Front roof rack
I saw a rack that mounts before the penthouse anyone got a line on who makes it?
2000 Ford RB30 PH 2WD -- Eagle Rock California
stiggs is offline   Reply With Quote
Old 01-31-2021, 11:16 AM   #2
Orv
I think the few I've seen here have been custom jobs. I'd potentially be interested too, though. My Westy had one and it was handy now and then.
N8SRE
Old 01-31-2021, 11:22 AM   #3
stiggs's Avatar
Yep super handy when I had a Westy
Old 01-31-2021, 12:31 PM   #4
Twoxentrix's Avatar
@stiggs - Might consider reaching out to member Marret. He has one on the front, and he may also be able to direct you to a thread that was active a year or so ago - included quite a long discussion (and suggestions) on the same topic.
Old 01-31-2021, 12:56 PM   #5
marret's Avatar
You call @Twoxentrix?
The thread is linked below. Mine is the one linked in my post, and below, cut to fit and mounted on Thule gutter mounts.
Thread link:
https://www.sportsmobileforum.com/fo...use-26566.html
Rack link:
https://www.amazon.com/59504-V-Tex-R...s%2C154&sr=8-1
Chris
Old 01-31-2021, 04:04 PM   #6
Orv
That thread got me thinking about adapting hitch carrier baskets. The Harbor Freight #69858 "ATV cargo carrier" seems like it might be a good size if I discarded the hitch mount and bolted the two halves directly together. I'd still need a way to mount to the rain gutters, though.
N8SRE
Old 01-31-2021, 07:42 PM   #7
BrianW's Avatar
Hmmm, that’s an interesting idea! I have an aluminum HF cargo carrier in the shed and some old Yakima 1A raingutter towers too. Would be pretty easy to cobble together.
Old 02-07-2021, 10:30 PM   #8
Orv
Most gutter-mount rack systems are pretty expensive -- often a couple hundred bucks just for the mounts, and the vans require extra-long crossbars. The cheapest DIY option I found is this:
https://www.ksuspensionfab.com/store..._Mounts.html#/
$60 for a set of four. They're designed for a Jeep XJ but I suspect the rain gutter profile is not that different.
After some quick measurements I think the HF #66983 "500 lb. Steel Cargo Carrier" is going to be a better fit than the ATV carrier. The van roof is wider than I'd have thought. I'm going to hold off on ordering any kind of basket until I've mocked up the gutter mounts, though. The cargo carrier is massive overkill strength-wise but I haven't found a cheaper cargo basket yet. HF does sell a 150 pound capacity rooftop basket type carrier, but it's very narrow (36 inches) and I'd prefer to get closer to the full width of the roof.
N8SRE
Old 02-08-2021, 07:56 PM   #9
I can make you one your local. Or you can make one yourself. Get the gutter mounts. go to home depot and buy the sort wrought iron gate they have. I think they have a 48" and a 60" tall and they have 2 widths. Obviously get the narrower one. You can also go to a metal fab shop and they can make you one. The home depot would be a good start.
Old 02-08-2021, 09:09 PM   #10
Orv
Ah, interesting idea. I'll have to take a look at what Home Depot has.
N8SRE
undecided
JOELMUNOZ3
Van22
Van22
