Old 08-31-2007, 04:43 PM   #11
Originally Posted by alta825
In my van which is a 01 RB-50, the side door cabinet has the upper 'door' that opens to form a table that is level w/ the top of the cabinet. It uses a pretty slick hinge that is sorta like the hinges on the folding 6 ft tables you see at home depot etc...
I can try to get a pic or two taken once I get some fresh batteries for the camera
D
Yeah, definitely post pics of that sucker!
2006 RB50 6.0 Diesel
SMB 4WD
Amsoil
Old 09-14-2007, 10:58 PM   #12
charlie56's Avatar
Swing Table Solution
The following was inspired after watching a TV show on luxury jets.
How about this for a solution to a casual table that swings?
The table is supported by a ½â€
... Charlie
KZ6T
Old 09-16-2007, 03:52 PM   #13
Buji's Avatar
Add cupholder holes that you can add 'caps' to so you don't lose things when you're not putting drinks in. Also, a raised, rounded lip around the outside isn't a bad idea to keep pencils and stuff (or spills) from escaping.
-Buji
_________________________
Modified EB-22 with Penthouse Top
https://www.sportsmobileforum.com/alb...43791a54be.jpg
Buji is offline   Reply With Quote
Old 09-17-2007, 07:15 PM   #14
alta825's Avatar
OK,
finally got around to going outside w/ the camera to take a few pics of the cabinet for y'all
it uses a locking sort of support that hinges out of the way sorta like to folding tables but smaller if you get my drift
probably would help if I took a shot of the support hinge - oops! you'll have to wait...
cheers,
D
2002 EB51 7.3L w/ Stage 2- UJoint 6" 4x4 Conversion
2001 RB50 V10 Quigley- SOLD
alta825 is offline   Reply With Quote
Old 09-17-2007, 09:18 PM   #15
Greg In Austin's Avatar
Charlie56,
You have come the closest to what my wife asked about when she started this thread. good job.
...so where can find these?
...or when will you start marketing them?
The key to what we are looking for is somthing that hides away and takes up little to no room, but ends up acting much like a TV-tray would at home by the couch.
Greg in Austin
SMB on order
Greg in Austin
Old 10-01-2007, 08:57 AM   #16
Greg I was pulling up www.ram-mount.com to link to and saw this image in their product slide show... immediately thought of your side table project. Since I hadn't heard any success stories I thought I'd throw this out as a possiblity:
Old 10-01-2007, 09:05 AM   #17
Jage,
Thanks for thinking of me... so far Charli has come the closest to what we are thinking about. We are exploring building out his idea.
We are going to use a RAM mount for the PC up front, in some configuration, and we may use RAM mounts in a couple of other areas.
...but I am not sure given the foot print of the laptop mounts that they would work as an eating or working ssurface at the goucho.
We will keep all informed as the van gets closer and we get further on the side table designs.
Greg in Austin
SMB on order
Greg in Austin
Old 10-01-2007, 09:37 AM   #18
Yeah, but you could make the table surface from MDF or better yet, plywood and cover with shelf paper. There are so many RAM mounts that twist and turn and tilt... just get the laptop holder but not the final laptop mount. Get one of their connectors that can bolt to the back of plywood (we did this before on something with RAM mounts), and you've got whatever you want...
SMB 4WD
Amsoil
Old 10-01-2007, 07:14 PM   #19
....but where would you attach the RAM Mount?
Don't get me wrong, I think RAM Mounts are great; I bet we end up with 5 or 6 in our SMB.
...but we are looking for something more TV-tray-like.... small, lightweight, easy to store away.
How would you get a RAM mount to do this at each end of a gaucho? and also have the ability to disappear from sight...
Greg in Austin
SMB on order
PS : the FORD order and 4WD options were finalized today and it should be on the FORD production line in the next 2 weeks.
Greg in Austin
