Old 08-28-2013, 01:17 PM   #1
Bed Rug Anyone?
Right now I have 1/2 of rigid foam and 1/2 plywood as my flooring, and looking to add carpeting on top of that. Anyone have experience with a Bed Rug? They seem pretty nice and fit in perfectly. I'm almost thinking about scrapping the floor I have right now to put one of these in. You think it provides the same about of sound dampening?
http://www.autoanything.com/cargo-liner ... 7A0A0.aspx
dudewithvan is offline   Reply With Quote
Old 08-28-2013, 03:23 PM   #2
Re: Bed Rug Anyone?
I've got one in my pickup. It's a quality product. The fit is perfect and I really like the way the foam backing matches the ribs on the floor. Easy to clean and very comfortable.
redtop is offline   Reply With Quote
Old 08-28-2013, 05:03 PM   #3
shenrie's Avatar
Re: Bed Rug Anyone?
thats pretty slick.
Old 08-29-2013, 08:07 AM   #4
Re: Bed Rug Anyone?
Yes I put one in my van above the rattle trap sound stuff. Removed the factory mat and used this one instead. Its closed foam so will not collect moisture. After that I put down 3/4" plywood and now will be covering that in vinyl floor once I fill in the seams. I was told this is how Sports Mobile does their rigs as well. Not sure if that's true but I like it all the same. It is a little lighter than I thought it would be.
edaddy is offline   Reply With Quote
Old 09-01-2013, 09:30 AM   #5
UJOINT's Avatar
Re: Bed Rug Anyone?
I've installed a few of these, really nice. Great fit & finish, good price too!
Chris Steuber
02 E350 7.3 (V4)
ujointoffroad.com
Old 01-29-2024, 06:26 PM   #6
Does this contour around the floor ribs? aka is it flat on top, I was considering using it for the base layer of my flooring system.
06 E-350 EB 6.0 Suckless Quigley (Bulletproofed with RIP)
seal is offline   Reply With Quote
Old 01-29-2024, 07:27 PM   #7
1der's Avatar
The Bed Rug is flat on top and works well as an insulating base under plywood. It provides a thermal and sound break from the metal floor. Of course, if screws are driven through the plywood into the metal floor then the "breaks" are compromised.
This is the one I and others have used in our builds:
https://www.amazon.com/BedRug-VanRug...ine+Club+Wagon
Old 01-29-2024, 07:33 PM   #8
yes it is.
I was glad to see this post by edaddy. I had already decided to put 3/4" ply over the van rug for sound deadening and custom floor leveling.
There are two styles, one is more of a hard "rubber-like" top (in black) while the other is a fuzzy rug texture. They are made of the same thing just how it is formed.
Vanrug seems to be the fuzzy type and Vantred is the harder rubber-like top. Both have the bottom ribbing. Which is better for a 3/4" ply over lay as far as sound deadening? I don't know.
The vantred is probably easier to drill although I have used a soldering iron to melt back the material in a through hole.
FYI whether RB or EB they only cover the cargo area.
https://www.amazon.com/BedRug-VanRug...2-63e904010ad0
