Re: Gravity based water system?
[photo] [/photo]
I use a "Whale" hand pump mounted behind my sink. Works great, a lot of water per stroke and simple design means little to go wrong. They are used a lot in the marine industry, they have a long history and good reputation. I have a 20 gallon water tank under the bed right over the rear axle. In the winter just drain the tank and pump the handle a couple of times and they are good for freezing weather.
2007 EB 15-PASS, 5.4L, 265/75R16, 4.10 gears, 2" lift, Camper Conversion
