Old 07-23-2012, 05:08 PM   #1
Homebuild under van propane tank?
Someone here has done it, I've seen it. Who are you?
I'm about to weld up something to hold a BBQ grill 20 gal tank under the van. Mine's a EB Ford do there's a good spot for it in the middle right behind the rear axle.
Sorry, search function isn't helping.
Thx
Old 07-23-2012, 07:18 PM   #2
MadScience's Avatar
Re: Homebuild under an propane tank?
Probably obvious: Don't weld to the tank unless you're capable of pressure testing it and re-certifying it. Otherwise random places have every right to refuse to fill it.
Old 07-23-2012, 08:38 PM   #3
My plan is to weld up a cage for a BBQ tank under there. I'm not planning on welding the tank in permanently. There is a guy on the forums who has done this, i'm just gathering ideas.
Old 07-23-2012, 08:44 PM   #4
You have enough space for a 20 lb tank that is vertical? Those things won't work on their side.
Old 07-23-2012, 10:00 PM   #5
Get a fork lift tank. Most have a nice gauge on them too.
Old 07-23-2012, 10:29 PM   #6
Good idea Dave! Will that work? I mean, can I easily find the fittings, etc. to mate it to a Suburban furnace?
CarringB, I guess I knew that but had forgotten. Anyway, If I can find the thread it had pics and everything of how he mounted a 20lb. underneath in the back. A forklift tank may be a better idea anyway.
Old 07-23-2012, 11:06 PM   #7
You'll have to look into it. Most forklifts run on liquid fuel but I have one that has the valve on top of the tank. It has a flat bracket on the base that I drilled holes into and put castors on it so I can push it around. Use it for a set of propane heaters. If you can find one of those it would work out fine for you. If I find one similar I'll post back.
Old 07-23-2012, 11:18 PM   #8
looks like this but larger around:
The gauge is on the end of the tank
Old 07-24-2012, 10:39 AM   #9
Check this out:
Double the capacity, but its composite so its lightweight, and you can see the liquid inside.
http://www.globalindustrial.com/p/sa...FYUaQgodJQYA5A
Downside of a forklift tank is you will need a vaporizing regulator (aka vaporizer), which look kind pricey.
Some 5th wheels and truck campers come equipped with horizontal RV tanks, which will draw vapor instead of liquid.
Old 07-24-2012, 10:50 AM   #10
dhally's Avatar
I think the DOT approved tanks are more rugged to help survive a crash. They also have a special check valve that is supposed to shut off flow if the piping or valve is broken off. If safety is a concern, it might be best to use the DOT approved tanks with the latest safety check valve. Don't know if the fork lift tanks are DOT approved.
2009 E250 RB 5.4L "SilVan"
The SMB
Economan
MoMo
skyrat
